Michael Thompson Guest
Relocation of reset and interrupt vectors and #org for bootl |
Posted: Wed Jan 15, 2003 6:52 pm |
I have been trying to compile code for the PIC18F8720 that can be downloaded by a bootloader. However, the CCS V3.119 compiler seems not to properly interpret some pragmas correctly and seems to ignore another completely. The following are the pragmas that I have been trying to use to direct the compiler where to place code and to prevent the compiler from using the boot block, 0x0000 to 0x01FF.
#build(reset=0x0100)
#build(interrupt=0x0104)
#org 0x0000,0x01FF {}
The two #build pragmas seem to multiply the value given by two. #build(reset=0x0100) places the reset vector at 0x0200 and #build(interrupt=0x0104) places the interrupt vector at 0x0208. I originally had tried #build(reset=0x0200) and #build(interrupt=0x0208) and the compiler put reset and interrupt at 0x0400 and 0x408, respectively.
According the the compiler documentation, #org 0x0000,0x01FF {} is supposed to prevent the compiler from using the program memory from 0x0000 to 0x01FF. However, the compiler insists on placing code and/or data in this area, regardless of the pragma.
I have tried every combination of the #org statement possible. When I don't use the {}, I get the compiler error "Invalid org range" regardless of the values given, even when I don't include addresses 0-3.
Thoughts?
___________________________
Original Post ID: 10731 |
Gary Smithson Guest
Re: Relocation of reset and interrupt vectors and #org for b |
Posted: Wed Jan 15, 2003 9:06 pm |
I can't help very much but I can vouch for the following code to reserve program space in a mid-range family device (PIC16F877). If all is working properly then the family shouldn't matter.
// Reserve 0x0004 through 0x17FF
#org 0x0004, 0x07FF {}
#org 0x0800, 0x0FFF {}
#org 0x1000, 0x17FF {}
This on the other hand would NOT work
#org 0x0004, 0x17FF {}
Sorry I can't remember the version of the compiler in use at the time but it was 3.xxx. Maybe in todays version the entire range can be given in one statement.
Hope this helps,
Gary S.
:=I have been trying to compile code for the PIC18F8720 that can be downloaded by a bootloader. However, the CCS V3.119 compiler seems not to properly interpret some pragmas correctly and seems to ignore another completely. The following are the pragmas that I have been trying to use to direct the compiler where to place code and to prevent the compiler from using the boot block, 0x0000 to 0x01FF.
:=#build(reset=0x0100)
:=#build(interrupt=0x0104)
:=#org 0x0000,0x01FF {}
:=The two #build pragmas seem to multiply the value given by two. #build(reset=0x0100) places the reset vector at 0x0200 and #build(interrupt=0x0104) places the interrupt vector at 0x0208. I originally had tried #build(reset=0x0200) and #build(interrupt=0x0208) and the compiler put reset and interrupt at 0x0400 and 0x408, respectively.
:=According the the compiler documentation, #org 0x0000,0x01FF {} is supposed to prevent the compiler from using the program memory from 0x0000 to 0x01FF. However, the compiler insists on placing code and/or data in this area, regardless of the pragma.
:=I have tried every combination of the #org statement possible. When I don't use the {}, I get the compiler error "Invalid org range" regardless of the values given, even when I don't include addresses 0-3.
:=Thoughts?
Original Post ID: 10732 |
David Aarons Guest
Posted: Thu Jan 16, 2003 10:25 am |
Hi .. Please can you send me your email address and I will send you our bootloader which should get rid of your hassles.
David Aarons
sales@selectsoftware.net
:=Thoughts?
Original Post ID: 10738 |
Gerrit Faas Guest
Posted: Thu Jan 16, 2003 6:27 pm |
Hello David,
I'm just starting project with 18F6720 for data logging and am looking for a bootloader.
Is it posible to get your bootloader as well.
If so I have included my e-mail address.
Regards,
Gerrit Faas
:=Hi .. Please can you send me your email address and I will send you our bootloader which should get rid of your hassles.
:=David Aarons
:=sales@selectsoftware.net
:=:=I have been trying to compile code for the PIC18F8720 that can be downloaded by a bootloader. However, the CCS V3.119 compiler seems not to properly interpret some pragmas correctly and seems to ignore another completely. The following are the pragmas that I have been trying to use to direct the compiler where to place code and to prevent the compiler from using the boot block, 0x0000 to 0x01FF.
:=:=#build(reset=0x0100)
:=:=#build(interrupt=0x0104)
:=:=#org 0x0000,0x01FF {}
:=:=The two #build pragmas seem to multiply the value given by two. #build(reset=0x0100) places the reset vector at 0x0200 and #build(interrupt=0x0104) places the interrupt vector at 0x0208. I originally had tried #build(reset=0x0200) and #build(interrupt=0x0208) and the compiler put reset and interrupt at 0x0400 and 0x408, respectively.
:=:=According the the compiler documentation, #org 0x0000,0x01FF {} is supposed to prevent the compiler from using the program memory from 0x0000 to 0x01FF. However, the compiler insists on placing code and/or data in this area, regardless of the pragma.
:=:=I have tried every combination of the #org statement possible. When I don't use the {}, I get the compiler error "Invalid org range" regardless of the values given, even when I don't include addresses 0-3.
:=:=Thoughts?
Original Post ID: 10743 |
Gerrit Faas Guest
Posted: Thu Jan 16, 2003 6:29 pm |
Hello David,
Regards,
Gerrit Faas
:=David Aarons
:=:=Thoughts?
Original Post ID: 10744 |
IK1WVQ Guest
#BUILD(...) directive syntax ??? |
Posted: Mon Jan 20, 2003 12:03 pm |
hi,
see the "DEFAULT" option in #org pragma ....
i solved all my problem with this ..
regards
:=Thoughts?
Original Post ID: 10823 |
Posted: Mon Jan 20, 2003 12:59 pm |
:=Thoughts?
Original Post ID: 10827 |
Ron Guest
Posted: Mon Jan 27, 2003 5:03 am |
My compiler (v3.137) tells me 'INVALID ORG RANGE' When using
Any clues why Gary S. get's the thing to work?
Best Regards,
Ron
:=I can't help very much but I can vouch for the following code to reserve program space in a mid-range family device (PIC16F877). If all is working properly then the family shouldn't matter.
:=// Reserve 0x0004 through 0x17FF
:=#org 0x0004, 0x07FF {}
:=#org 0x0800, 0x0FFF {}
:=#org 0x1000, 0x17FF {}
:=This on the other hand would NOT work
:=#org 0x0004, 0x17FF {}
:=Sorry I can't remember the version of the compiler in use at the time but it was 3.xxx. Maybe in todays version the entire range can be given in one statement.
:=Hope this helps,
:=Gary S.
:=:=Thoughts?
Original Post ID: 11024 |
joe06 Guest
Posted: Mon Jul 28, 2003 1:49 pm |
I have the same problem, I cannot compile a ORG pragma overriding the reset vector 0x00 to 0x03 !?
did you solve your problem ?
Original Post ID: 144516442 |
Eric Elias Guest
Posted: Thu Aug 14, 2003 1:26 pm |
:=Thoughts?
Original Post ID: 144516969 |
