taubek
Problem! |
Posted: Tue Apr 17, 2007 8:43 am |
Hi!
I'm using CCS C compiler only for a short time. I got problem with compiling, i got error unknovn device type. But few days ago i compiled the same source code without any problems. I'm using PIC 16F767.
Can you help me? Sorry about my english, i'm not from UK or USA.
Thanks. |
elphi
Joined: 17 Apr 2007 Posts: 20 Location: tijuana,bajacalifornia,mexico
Re: Problem! |
Posted: Tue Apr 17, 2007 9:24 am |
taubek wrote: | Hi!
Thanks. |
1. - Can you post the code?
2.- Witch version of CCS c are you using.
3.- Witch is your native language.(I'm not form uk or usa neither) _________________ Every little thing gonna be alright |
taubek
Re: Problem! |
Posted: Tue Apr 17, 2007 12:23 pm |
elphi wrote: |
3.- Witch is your native language.(I'm not form uk or usa neither) |
#include <16F737.h>
#fuses INTRC,NOWDT,NOPROTECT,NOMCLR,NOPUT
#use delay(clock=4000000);
#define RA0 PIN_A0
#define RA1 PIN_A1
#define RA2 PIN_A2
#define RA3 PIN_A3
the code is ok, i have to set some settings or something, i have programmed the same program on the same type of PIC a week ago.
I thing i should set something there where i can choose 12 bit Microchip, 14 bit Microchip and Microchip PIC18.
I tried version IDE 3.40 from year 2003 and the newest demo program from ccs web page.
My native language is Slovene. |
taubek
Posted: Tue Apr 17, 2007 12:38 pm |
I tried many options till now and i found out that i can compile PIC 16F877A without problems on Microchip 14bit options.
Code for that 16F877A chip start like that:
#include <16F877A.h>
#fuses HS, NOWDT,NOPROTECT, NOLVP
#define ...
code for PIC 16F767 or 12F765 still cannot be compiled but it works for 16F648A |
Posted: Tue Apr 17, 2007 1:09 pm |
That's not the compiler version. You can find the compiler version
at the top of the .LST file for your project. The .LST file will be in
the project directory, after you have successfully compiled your
source files.
Look for 4-digit number, such as 2.734, or 3.191, or 3.249, etc.
That's the compiler version. |
Posted: Tue Apr 17, 2007 3:17 pm |
Quote: | I tried many options till now and i found out that i can compile PIC 16F877A without problems on Microchip 14bit options. | Sounds like you are using the free compiler demo version which is limited to the Microchip 14 bit PIC16F877(A), PIC16C544 and 16 bit PIC18F458 target devices. |
taubek
Posted: Wed Apr 18, 2007 12:49 am |
ckielstra wrote: | Quote: | I tried many options till now and i found out that i can compile PIC 16F877A without problems on Microchip 14bit options. | Sounds like you are using the free compiler demo version which is limited to the Microchip 14 bit PIC16F877(A), PIC16C544 and 16 bit PIC18F458 target devices. |
It works for PIC 16F648A too. |
Posted: Wed Apr 18, 2007 2:17 am |
taubek wrote: | It works for PIC 16F648A too. | Than it most likely isn't a demo version of the compiler.
You didn't answer PCM's question about the compiler version, check his post here above for how to find the compiler version number. |
taubek
Posted: Wed Apr 18, 2007 5:57 am |
I think is 3.180 |
taubek
Posted: Wed Apr 18, 2007 6:06 am |
can somebody tell me what means PCm, PCH and PCB? which should i use? I have licence files with this names. Is that a trouble? |
taubek
Posted: Wed Apr 18, 2007 6:26 am |
ammm, i think i found a problem. I copyed some device files into a map "devices" but when i try to start new project at PIC wizard there are those added devices not listed.
How to add those? I think that would be solution. |
Posted: Wed Apr 18, 2007 6:54 am |
taubek wrote: | can somebody tell me what means PCm, PCH and PCB? | These are names for the different compilers:
PCB = PIC10 and PIC12 (12 bit)
PCM = PIC16 (14 bit)
PCH = PIC18 (16 bit)
Quote: | ammm, i think i found a problem. I copyed some device files into a map "devices" but when i try to start new project at PIC wizard there are those added devices not listed.
How to add those? I think that would be solution. | Hmmmm..... Did you tell us everything we should know? You told us you didn't change a thing when suddenly compiling for the PIC16F767 failed.
Now I get the feeling that you are trying to compile for a completely different processor you didn't mention before. Which processors can you compile for and which one does fail? |
taubek
Posted: Wed Apr 18, 2007 7:22 am |
ckielstra wrote: | taubek wrote: | can somebody tell me what means PCm, PCH and PCB? | These are names for the different compilers:
I'm trying to compile for PIC 16F767 and that failed (Unknown file type).
I have that file in map devices but when i try to make new project i cannot select PIC 16F767 because it is not on the list and i dont know how to add it. I think that's a problem. |
rwyoung
Posted: Wed Apr 18, 2007 7:42 am |
And you have contacted CCS support directly, given them your customer number and asked for help with your errant compiler installation, right?
Or are you trying to use a "borrowed" copy of the compiler (a no-no). _________________ Rob Young
taubek
Posted: Wed Apr 18, 2007 11:27 am |
rwyoung wrote: | And you have contacted CCS support directly, given them your customer number and asked for help with your errant compiler installation, right?
Or are you trying to use a "borrowed" copy of the compiler (a no-no). |
no i didnt ask there, i tought i can get some information here. |
