serial communication for pic
globalsys
PostPosted: Tue Apr 17, 2007 4:28 am     Reply with quote
Hello.
I have to establish a serial communication between a pic 18F6520 and a OKI's IC for vox synthesis ML22Q54.
For that, I would like to know if somebody can advise me before begining, as soon as possible.
I would like to do a function which respect the following link:
Best regard
PostPosted: Tue Apr 17, 2007 11:26 am     Reply with quote
The timing looks similar to SPI, except that it has \Read and \Write
signals that must also be set (with two more i/o pins), in addition to
the normal \CS signal. Therefore, you can use the PIC's hardware
SPI module to provide the interface to the chip.
Read my posts in the following threads, where I talk about how to
determine the SPI mode and use CCS functions to implement it.
http://www.ccsinfo.com/forum/viewtopic.php?t=30477
http://www.ccsinfo.com/forum/viewtopic.php?t=29656
http://www.ccsinfo.com/forum/viewtopic.php?t=29410
globalsys
PostPosted: Wed Apr 18, 2007 1:49 am     Reply with quote
Thanks you very much PCM programmer for tour help
