MAX517 !! error
ali6094
MAX517 !! error
PostPosted: Sun Apr 15, 2007 10:51 pm     Reply with quote
hello
i am using PIC16F877A and max517 .. the purpose it to generate different analogue signals ... i have designed the circuit and the code is down it was taken from the CCS code library but no out puts -- circuit is like dead the code is as follow...
#include <16F877A.h>
#device ICD=TRUE
#device ADC=10 // Use 10bits ADC
#use delay(clock=20000000) // 20Mhz Crystal is Used
#include <MAX517.c>  //Call for MAX517.c function
#define TRIGGER  PIN_E0
#define SAMPLE1  PIN_C4
#define SAMPLE2  PIN_D2
#define SAMPLE3  PIN_C5
int1 data_end = 0;
   set_tris_d( 0xff );
   set_tris_c( 0xbf );
   set_tris_e( 0xff );
Begin:
if (TRIGGER)
      data_end = 0 ;
      goto  Begin ;
   if (!TRIGGER && !data_end)
      if (!SAMPLE1)
               output_high(PIN_A0); //LED ON
               write_dac(0xFF);     //DAC output 5V
            delay_ms(5000);    //Delay
            output_low(PIN_A0); //LED OFF
            write_dac(0x00);   //DAC output 0V
         data_end = 1 ;
      if (!SAMPLE2)
         data_end = 1 ;
      if (!SAMPLE3)
         data_end = 1 ;
      goto Begin ;
here is the circuit
http://www.mediafire.com/?9w2qmm4oihy
[/list]
PostPosted: Mon Apr 16, 2007 11:56 am     Reply with quote
Start with a small test program and use the CCS driver instead of
something you found in the Code Library. Here's the driver location:
c:\Program Files\Picc\Drivers\MAX517.c
PostPosted: Mon Apr 16, 2007 12:38 pm     Reply with quote
if (TRIGGER)
This ain't going to work, change this line to
if (input(TRIGGER))
Same note applies to SAMPE1, SAMPLE2 and SAMPLE3.
The use of the goto statement in the C-language is discouraged as it often leads to difficult to maintain code. More elegant solutions are possible, for example you can replace
Begin:
   if (input(TRIGGER))
      data_end = 0 ;
      goto  Begin ;
by
while (input(TRIGGER))
  // Do nothing while waiting
data_end = 0;    // note that this line is not required, you already initialized the global variable to zero.
   set_tris_d( 0xff );
   set_tris_c( 0xbf );
   set_tris_e( 0xff );
By default the CCS compiler is using 'standard I/O' in which the compiler sets the right TRIS values for you. This means that the lines above are not required and can change compiler defined values.
ali6094
no out put
PostPosted: Sun Apr 22, 2007 4:55 pm     Reply with quote
Well i am doing alot of things but nothing is really working can u plz check my circuit diagram is it fine i dont know whats wrong i am getting my LED fine lit but no out puts i.e Zero volts.... can any body tell me why.....
[/img]
Push switch for input is a selector switch to choose between the POT or DAC but DAC is giving no output just for start
my code is
#device ICD=TRUE
#use delay(clock=20000000) // 2016Mhz Crystal is Used
   write_dac(0xF0);     //DAC output 5V
   write_dac(0xF0);
   delay_ms(5000);
   delay_ms(5000);
   delay_ms(5000);
Can there be any proble, with the address of the device eith me the routine is
void write_dac(int data_byte) {
 i2c_start();
 [b]i2c_write(0x5e); [/b]          // Send the address of the device
 i2c_write(0);
 i2c_write(data_byte);      // Send the data to the device
 i2c_stop();
PostPosted: Sun Apr 22, 2007 7:03 pm     Reply with quote
The slave address of 0x5E is not correct for your hardware connections.
For your hardware, it's actually 0x58. You need to edit the write_dac()
function and change it.
Also, your schematic shows capacitor C21 is installed backwards.
The '+' side should go to Vdd. If you install a polarized capacitor
backwards, it can blow, or it can leak fluid, or it can slowly eat
through the membrane and turn into a resistor. All of these are bad.
Fix the schematic and replace the capacitor with a new one.
ali6094
PostPosted: Mon Apr 23, 2007 3:24 pm     Reply with quote
Thanx PCM programmer
those were the real two problems and now i have fixed both of them and i am getting the desired out put ... u have always been a sourse of great help and i would like to show my gratitude for your support
Ali
Smile
