interrupts disabled by compiler
ryan.reeve
PostPosted: Mon Apr 16, 2007 1:12 am     Reply with quote
I am using compiler 4.013.The only interrupt I am using is #int_rda.
The programs compiles sucessfullly but compiler disables the interrupt and show the warning:
" Interrupt disabled during call to prevent re-entrancy: [@DIV88]"
and line no. it shows, dont even exists in the code.Any ideas ?
#include <lcd.h>
#include <420_lcdd.c>
#include<stdio.h>
#include<stdlib.h>
#include<string.h>
#define SIZE 80
#define COMMA 0x2C
#use rs232(baud=4800, xmit=PIN_C6, rcv=PIN_C7, stream=GPS, errors)
void parse();
void rmc();
void gga();
void rmb();
void show();
unsigned char *pChar,LastComaPos;
unsigned int j,k;
unsigned char inStr[SIZE];
float bearing=0.0;
int alt=0;
float latitude,longitude;
float speed=0.0,heading=0.0;
BYTE next_out = 0;
int index=0;
short int sentence;
#INT_RDA
void GPS_isr()
   int t;
   char char_rcvd;
   char_rcvd=fgetc(GPS);
   if(char_rcvd=='$')
     index=0;
     sentence=true;
    if((char_rcvd==10)||(char_rcvd==13))
      sentence=false;
if(sentence)
   inStr[index]=char_rcvd;
   t=index;
   index=(index+1) % SIZE;
   if(index==next_out)
     index=t;
/*#INT_TIMER0
void timer0_int()
   set_timer0(61); // 61 for 20 msec
   //lcd_init();
   //setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);
   enable_interrupts(INT_RDA);
   //enable_interrupts(INT_TIMER0);
     parse();
     show();
void parse()
   if(inStr[0] != '$')
   printf("No Valid Data\n\r");
     // lcd_putc("\f");
     // lcd_gotoxy(1,1);
     // lcd_putc(" No Data");}
      if(inStr[3]=='R' && inStr[4]=='M' && inStr[5]=='C')
         rmc();
      else if(inStr[3]=='G' && inStr[4]=='G' && inStr[5]=='A')
         gga();
      else if(inStr[3]=='R' && inStr[4]=='M' && inStr[5]=='B')
         rmb();
void show()
{    //////////// To Get output on Terminal window uncomment the following ///////////////////
  //set_uart_speed(4800);
  printf("\n\r%3.6f",Latitude);
  printf("\n\r%3.6f",Longitude);
  printf("\n\r%3.2f",speed);
  printf("\n\r%3.2f",bearing);
  printf("\n\r%u",alt);
  printf("\n\r%3.2f",heading);
  getc();
  //////////// To Get output on LCD uncomment the following ///////////////////
  /*lcd_putc("\f");
  lcd_putc(inStr);
  lcd_gotoxy(2,1);
  printf(lcd_putc,"V %3.2f ", speed);
  lcd_gotoxy(8,1);
  printf(lcd_putc, "  BRG %3.2f",bearing);
  lcd_gotoxy(2,2);
  printf(lcd_putc,"\n ALT %3.2f", alt);
  lcd_gotoxy(11,2);
  printf(lcd_putc," HDG %3.2f", heading);
  lcd_gotoxy(2,3);
  printf(lcd_putc,"\n LAT.  %3.6f" ,Latitude);
  lcd_gotoxy(2,4);
  printf(lcd_putc,"\n LONG. %3.6f ",Longitude);*/
/////////GGA sentences needed to compute Altidute////////
/// found after 9 commas///////
void gga()
   unsigned int comacount,i=0;
   unsigned char altstr[5];
     pChar=inStr;
     k=0;
     comacount=0;
      while(comacount<10)
            if (inStr[i]==COMMA)
                   comacount++;
                   if (comacount==9)
                      j=i+1;
                      while(*(pChar+j) !=COMMA)
                           altstr[k]=inStr[j];
                           j++;
                           K++;
           i++;
 altstr[k]='\0';
 alt=atof(altstr);
 //printf("Altitude   ");
 //puts(altstr);delay_ms(250);
/////////RMB sentences needed to compute True Bearing////////
/// found after 11 commas///////
void rmb()
   unsigned char bearstr[5];
     pChar=inStr;
     k=0;
     comacount=0;
      while(comacount<12)
                   comacount++;
                  if (comacount==11)
                      j=i+1;
                           bearstr[k]=inStr[j];
                           j++;
                           K++;
           i++;
 bearstr[k]='\0';
 bearing=atof(bearstr);
 //printf("\n Bearing   ");
 //printf(lcd_putc,"\n\%f",bearing);
void rmc()
   unsigned char latiStr[8];
   unsigned char latiCard[1];
   unsigned char longiStr[9];
   unsigned char longiCard[1];
   unsigned char speedStr[6];
   unsigned char headingStr[6];
   Long  latDegrees;
   float latMin;
   Long  longDegrees;
   float longMin;
     /*Extracht Time*/
     pChar=inStr;
     j=7;
     k=0;
         //timeStr[k]= *(pChar+j);
    j++;
    k++;
     //timeStr[k]='\0';
// Go to Next comma
 LastComaPos=j;
 pChar=inStr;
 j=LastComaPos+1;
      j++;
/* Extract Latitude*/
 LastComaPos=j;
 pChar=inStr;
 j=LastComaPos+1;
 k=0;
     latiStr[k]=*(pChar+j);
     j++;
     k++;
 latiStr[k]='\0';
 latitude = atof(latiStr);
//////////*Extract Latitude Cardinal*//////////////
 LastComaPos=j;
 pChar=inStr;
 j=LastComaPos+1;
 k=0;
     latiCard[k]=*(pChar+j);
     j++;
     k++;
 latiCard[k]='\0';
 latDegrees = (long)(latitude/100);
 latMin = (float)(latitude-latDegrees*100);
 latMin=latMin/60;
 latitude=latDegrees;
 latitude+=latMin;
/* Extract Longitude*/
 LastComaPos=j;
 pChar=inStr;
 j=LastComaPos+1;
 k=0;
     longiStr[k]=*(pChar+j);
     j++;
     k++;
 longiStr[k]='\0';
/*Extract Longitude Cardinal*/
 LastComaPos=j;
 pChar=inStr;
 j=LastComaPos+1;
 k=0;
     longiCard[k]=*(pChar+j);
     j++;
     k++;
 longiCard[k]='\0';
 longitude = atof(longiStr);
 longDegrees = (Long)(longitude/100);
 longMin = (float)(longitude-longDegrees*100);
 longMin=longMin/60;
 longitude=longDegrees;
 longitude+=longMin;
////////////Extract speed///////////
 LastComaPos=j;
 pChar=inStr;
 j=LastComaPos+1;
 k=0;
     speedStr[k]=*(pChar+j);
     j++;
     k++;
 speedStr[k]='\0';
 speed=atof(speedStr);
////////////Extract Heading////////////////
 LastComaPos=j;
 pChar=inStr;
 j=LastComaPos+1;
 k=0;
     headingStr[k]=*(pChar+j);
     j++;
     k++;
 headingStr[k]='\0';
 heading=atof(headingStr);
PostPosted: Mon Apr 16, 2007 1:30 am     Reply with quote
See the example code for using "#org default", near the end of each
of these threads:
http://www.ccsinfo.com/forum/viewtopic.php?t=25464&highlight=math+library
http://www.ccsinfo.com/forum/viewtopic.php?t=30018&highlight=org+default+wishes
