Software PWM 16F628A
A2B
PostPosted: Sat Apr 14, 2007 4:41 am     Reply with quote
I'm trying to make a software PWM for the 16F628A. This is for the RGB led i'm trying to make fading. Does anyone have a example for me.
I'm using PCWH compiler version 4.023
jecottrell
PostPosted: Sat Apr 14, 2007 8:25 am     Reply with quote
Use the forum search tool.
This is one of the topics I found helpful when I was faced with a similar project:
http://www.ccsinfo.com/forum/viewtopic.php?t=20050
John
mohikan
PostPosted: Sun Apr 15, 2007 3:26 am     Reply with quote
I had a similar project, the LEDs were connected to port RA (RA2=LED Blue, RA3=LED Red, RA4=LED Green) each with its own resistor (RA4 needs pull-up), the software PWM is in timer2 ISR and it's from a Microchip MicroSolutions Newsletter.
#include "RGBTest.h"
#INT_TIMER2
void TIMER2_isr()
   #asm
      movf    pwm_counter,w
      subwf    pwm_duty_green,w
      rlf    output,f
      movf    pwm_counter,w
      subwf    pwm_duty_red,w
      rlf    output,f
      movf    pwm_counter,w
      subwf    pwm_duty_blue,w
      rlf    output,f
      rlf      output,f
      rlf      output,w
      movwf    PORTA
      incf    pwm_counter,f
      clrf   output
   #endasm
#inline
void set_pwm_duty(ColorType color,int duty)
   switch(color)
      case RED:
         pwm_duty_red=duty;
      case GREEN:
         pwm_duty_green=duty;
      case BLUE:
         pwm_duty_blue=duty;
      default:break;
   set_tris_a(0x21);//00100001
      setup_timer_1(T1_DISABLED);
      setup_timer_2(T2_DIV_BY_1,0x4E,1);
      setup_vref(FALSE);
      setup_ccp1(CCP_OFF);
      printf("\n\rRGBTest v1.0 2006\n\r");
      switch(getc())
         case '7':
            ++pwm_duty_red;
            set_pwm_duty(RED,pwm_duty_red);
         case '4':
            --pwm_duty_red;
         case '8':
            ++pwm_duty_green;
            set_pwm_duty(GREEN,pwm_duty_green);
         case '5':
            --pwm_duty_green;
         case '9':
            ++pwm_duty_blue;
            set_pwm_duty(BLUE,pwm_duty_blue);
         case '6':
            --pwm_duty_blue;
         default:break;
      printf("> R:%03u G:%03u B:%03u\r",pwm_duty_red,pwm_duty_green,pwm_duty_blue);
#include <16F628A.h>
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES PUT                      //Power Up Timer
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD                    //No EE protection
#use rs232(baud=19200,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8,stream=UART)
#use fast_io(a)
#define   PORTA   0x05
typedef enum
   RED,
   GREEN,
   BLUE
} ColorType;
unsigned int pwm_counter=0;
unsigned int pwm_duty_red=0;
unsigned int pwm_duty_green=0;
unsigned int pwm_duty_blue=0;
unsigned int output=0;
A2B
PostPosted: Mon Apr 16, 2007 3:18 am     Reply with quote
Thank you for the code. This is most helpfull
