mcnscott2
another question on time project |
Posted: Sat Apr 14, 2007 1:28 pm |
I'm trying to add on more stuff to the time and temp project. I've added a battery back up now, however when I turn the clock off and then on it stays at the same time. This happens because the init function sets registers to the value in the code. A work around for me was to set the time I want in the registers, plug the chip into the project turn on the clock with the battery back up, then take the PIC out reprogram it by commenting out the set_time function.
This takes care of the problem sort of, when I turn the clock on and off the battery will keep the time great, but it won't advance the time until I power the clock back on. Is that clear as mud?
basically I can run the clock. lets say it shows 8:30 then I turn the clock off for ten minutes when I turn the power back on it still says 8:30, but then will start running normally. So does anyone have an idea of how I can get the clock to keep it's time internally while the power project is off,
and then get that out. I know it's somewhere in the clock RAM 08H-3FH
I've tried using some if statements to get it, but no luck really.
#include <SLED4C_1620a.h> // header file & function prototypes
void Main(void)
int announce=0; // holds # of time/temp announcements
init(); // initialize I/O & peripherals
while(1) // loop forever
read_time(); // read & display DS1307 time
read_temp(); // read & display DS1620 temp
// DID NOT INCLUDE THE REST OF MAIN NOT RELEVANT
// init calls this function
// set time & date on power-up
void set_time(void)
char i;
// put initial date/time into array
ds1307_regs[SECONDS_REG] = 55;// seconds
ds1307_regs[MINUTES_REG] = 59;// minutes
ds1307_regs[HOURS_REG] = 21;// hour
ds1307_regs[DAY_OF_WEEK_REG] = 0; // not used
ds1307_regs[DATE_REG] = 14;// date
ds1307_regs[MONTH_REG] = 07;// month
ds1307_regs[YEAR_REG] = 04;// year
// convert to BCD
for(i=0; i<7; i++)
ds1307_regs[i] = toBCD(ds1307_regs[i]);
ds1307_regs[SECONDS_REG] &= 0x7f;
ds1307_regs[HOURS_REG] &= 0x3f;
// write 7 bytes of BCD data to ds1307
i2c_start();
i2c_write(WRITE_CNTRL);
// start at seconds register
i2c_write(SECONDS_REG);
// write 7 bytes to registers 0 to 6
for(i=0; i<7; i++)
i2c_write(ds1307_regs[i]);
i2c_write(CONTROL_INIT_VAL);
i2c_stop();
// read time & date from DS1307
void read_time(void)
i2c_start();
// start i2c read at seconds register
i2c_start();
i2c_write(READ_CNTRL);
// read the 7 bytes from the ds1307. Mask off the unused bits
ds1307_regs[SECONDS_REG] = i2c_read() & 0x7f;
ds1307_regs[MINUTES_REG] = i2c_read() & 0x7f;
ds1307_regs[HOURS_REG] = i2c_read() & 0x3f;
ds1307_regs[DAY_OF_WEEK_REG] = i2c_read() & 0x07;
ds1307_regs[DATE_REG] = i2c_read() & 0x3f;
ds1307_regs[MONTH_REG] = i2c_read() & 0x1f;
ds1307_regs[YEAR_REG] = i2c_read(0);
i2c_stop();
stuff from SLED4C_1620a.h file
// DS1307 control bytes
#define WRITE_CNTRL 0xd0
#define READ_CNTRL 0xd1
// DS1307 register offsets
#define SECONDS_REG 0
#define MINUTES_REG 1
#define HOURS_REG 2
#define DAY_OF_WEEK_REG 3
#define DATE_REG 4
#define MONTH_REG 5
#define YEAR_REG 6
#define CONTROL_REG 7
#define DATE_TIME_BYTE_COUNT 7
#define DS1307_NVRAM_START_ADDR 8
#define CONTROL_INIT_VAL 0x80
Another question is what do these commands do? Why are they needed instead of just using the time specified times in the program?
And finally looking at the code where they mask off the unused bits the values they are using don't seem to match in the data sheet where do they get them?
but the data sheet says the address of the seconds register is 00H, but bit 7 has to be 0 to keep the oscillator running all these lines are saying they are masking off bits just kind of confusing me. Thanks for the help I know I'm asking a lot here. |
jecottrell
Posted: Sat Apr 14, 2007 3:41 pm |
It sounds like the CH (clock halt) bit isn't getting set to 0 in your init function... Where is your ds1307 init function?
Quote: | Another question is what do these commands do? Why are they needed instead of just using the time specified times in the program?
#define CONTROL_INIT_VAL 0x80 |
Use the search function to see where they are called and see what they do. If they're not called then they do nothing....
DS1307_NVRAM_START_ADDR is the offset to where the RAM is. (No your problem isn't there.... The RAM is just for storing stuff that may be needed between runs of the PIC. You shouldn't be concerned with this.
CONTROL_INIT_VAL is the value to be written to the control register. Use your Windows calculator in scientific mode and convert 0x80 to binary and see what registers are 1s and 0s when the control register is init'd.
The masking that is happening is a way of only updating the bits in a byte that you are interested in. Find a truth table for a logical AND and try to figure out what is happening in those statements.
What type of battery are you using?
After you post your DS1307 init function it should be easy to find the problem....
John |
mcnscott2
Posted: Sat Apr 14, 2007 5:36 pm |
hi John
here is the entire program code from Rentron's website
File name: SLED4C_1620a.c
Talking time & temp with display of time & temperature on the
SLED4C serial LED display module. Uses the DS1620 temp sensor,
DS1307 RTC, and EMIC text-to-speech module
When the temperature >= the high alarm setpoint, display the OUCH
message. Below setpoint, display the temp normally with voice
updates of time & temp on every hour.
MAX temperature range is from 0 to 99
void Main(void)
// announce time/temp on roll-over from 59 to 00 minutes
if(ds1307_regs[MINUTES_REG]==0x00)
if(!announce) // say time & temp only if announce=0
say_time(); // say the current time
delay_ms(3000); // delay 3 seconds
say_temp(); // say the current temperature
announce +=1; // increment announcement counts
if(!ds1307_regs[MINUTES_REG]==0x00)
announce=0; // clear announcements until it's time
// initialize hardware
void init(void)
port_b_pullups(FALSE); // portb internal pull-ups off
setup_comparator(NC_NC_NC_NC); // all comparators = off
disable(); // SLED4C enable pin must idle high
output_bit(CLK,0); // SLED4C clock pin must idle low
disable_interrupts(GLOBAL); // global interrupts off
setup_EMIC(2,1); // set EMIC volume 0=low 7=max & pitch
[b] set_time(); // set ds1307 time on power-up[/b]
init_1620(); // inititialize DS1620 temp sensor
setpoint=0x85; // set high temp alarm setpoint here
// shift out 8-bits in DAT MSB first
void send_byte(int DAT)
int n;
for(n=0; n<8; n++) // loop for 8-bits total
output_bit(DOUT,DAT & 0x80); // output MSB of 8-bit value
output_bit(CLK, 1); // clock pin = 1
output_bit(CLK, 0); // clock pin = 0
DAT = DAT << 1; // shift lower bits left into MSB of byte
// shift out low nibble in NIB MSB first
void send_nib(int NIB)
int n;
for(n=0; n<4; n++) // loop for 4-bits total
output_bit(DOUT,NIB & 0x08); // output MSB of 4-bit value
NIB = NIB << 1; // shift lower bits left into MSB of nibble
// take SLED4C enable pin low
void enable(void)
output_bit(EN,0); // this enables data entry into SLED4C
} // onboard config & data display registers
// take SLED4C enable pin high
void disable(void)
output_bit(EN,1); // this transfers data to the SLED4C internal
} // registers then disables further data entry
// write a byte to the DS1620
void write_1620(byte cmd)
byte i;
for(i=0; i<8; i++)
output_low(CLKD);
output_bit(DQ, shift_right(&cmd,1,0));
output_high(CLKD);
// initialize the DS1620
void init_1620(void)
// set CLK and RST to correct states
output_high(CLKD);
delay_us(2);
output_low(RST);
// set DS1620 config to continuous convert
// and CPU communications mode
output_high(RST);
write_1620(0x0C); // send Write Config command
write_1620(0x02); // configure for CPU mode, continuous convert
output_low(RST);
// start conversion
output_high(RST);
write_1620(0xEE); // send Start Convert command
output_low(RST);
// read & display temperature from DS1620.
void read_temp(void)
byte i;
output_high(RST);
write_1620(0xAA); // send Read Temp command
temp_data = 0; // clear temp_data on entry
for(i=0; i<9; i++) // loop for 9-bits
output_low(CLKD);
temp_data = temp_data >> 1;
if (input(DQ))
temp_data = temp_data | 0x100;
output_high(CLKD);
temp_data = temp_data/2; // convert temp_data to whole deg C
output_low(RST);
convert(); // convert C to F then to BCD
if (temp_r >= setpoint) // if temp >= setpoint display OUCH
ouch(); // call OUCH function if temp >= high setpt
return; // do not update temp display when temp >= setpt
enable(); // enable SLED4C data entry
send_byte(0b11001011); // digits 5,4,2 HEX decode. Digits 3,1 special
disable(); // write config value into config register
delay_ms(1); // short pause between config & display reg write
send_nib(0x00); // DIM display + DP's off
send_byte(temp_r); // display temp on digits 5/4
send_byte(0xFF); // display Deg F on digits 3/2
send_nib(0x00); // turn colon off
disable(); // write data into display registers
delay_ms(2000); // wait 2 seonds between temp & time updates
// convert temp from deg C to deg F, then pass
// to BCD conversion conversion function
void convert(void)
temp_data = (temp_data * 9/5)+32; // convert C to F
temp_r = toBCD(temp_data); // convert to BCD for display
// display OUCH when temp >= high alarm setpoint
void ouch(void)
int y = 8, n;
enable(); // enable data entry
send_byte(0b11010111); // digits 5,3 hex decode. 4,2,1 special
disable(); // write config data into config register
for(n=0; n<8; n++) // execute ouch display function 8 times
y ^= 8; // toggle y.bit.3
send_nib(y); // toggle DIM & BRIGHT, no DP's
send_byte(0x0A); // display OU on digits 5/4
send_byte(0xC2); // display CH on digits 3/2
disable(); // write display data into display registers
delay_ms(250); // set display "blink loop" delay time in mS
// this function converts an 8 bit binary value
// to an 8 bit BCD value. Input range from 0 to 99.
char toBCD(char bin_val)
char temp;
char retval;
temp = bin_val;
retval = 0;
// get tens digit by multiple subtraction
// of 10 from bin_val
if(temp >= 10)
temp -= 10;
retval += 0x10; // increment tens digit
else // get ones digit by adding remainder
retval += temp; // adjusted result
return(retval);
void set_time(void)
char i;
// convert to BCD
for(i=0; i<7; i++)
i2c_start();
for(i=0; i<7; i++)
i2c_stop();
i2c_start();
i2c_start();
i2c_stop();
send_byte(0b11000001); // all banks HEX decode
send_byte(ds1307_regs[HOURS_REG]); // display hour on banks 5/4
send_byte(ds1307_regs[MINUTES_REG]); // display minutes on banks 3/2
send_nib(0x02); // turn colon on
delay_ms(2000); // wait 2 seconds between temp & time updates
// say the time
void say_time(void)
printf("say=the time iz %X %X;",ds1307_regs[HOURS_REG],ds1307_regs[MINUTES_REG]);
delay_ms(2000); // allow time for message to play
} // adjust as required for message length
// say the temperature
void say_temp(void)
printf("say=the temperature iz %Ld degrees faren hyte;",temp_data);
// initialize EMIC module & set volume + pitch
void setup_EMIC(int vol, int pitch)
output_bit(EM_Rst,0); // hard reset the EMIC module
delay_us(200); // wait a minimum of 100uS
output_float(EM_Rst); // float reset output to release
delay_ms(1000); // wait for EMIC OK response before proceeding
printf("volume=%d;",vol); // send volume setting
printf("pitch=%d;",pitch);
The Header File:
File name: SLED4C_1620a.h
Header file for SLED4C_1620a.c
#include <16f876A.h>
#use rs232(baud=2400, xmit=PIN_C0)
#use i2c(Master, SDA=PIN_B0, SCL=PIN_B1)
// Define DS1620 interface pins
#define DQ PIN_B2 // Wire rb2 to pin #1 on DS1620
#define CLKD PIN_B3 // Wire rb3 to pin #2 on DS1620
#define RST PIN_B4 // Wire rb4 to pin #3 on DS1620
// Define SLED4C interface pins
#define EN PIN_B5 // Wire rb5 to enable pin #5 on SLED4C
#define CLK PIN_B6 // Wire rb6 to clock pin #4 on SLED4C
#define DOUT PIN_B7 // Wire rb7 to data pin #3 on SLED4C
#define HOURS_REG 2
#define DATE_REG 4
#define MONTH_REG 5
#define YEAR_REG 6
// EMIC text to speech constants
#define EM_Rst PIN_C1 // EMIC voice module reset pin #14
// Global vars
signed long temp_data; // raw temp
int8 temp_r; // final BCD temp result
int setpoint; // high temp setpoint
// PIC I/O & peripheral init function prototype
void init(void); // PIC port & peripheral initialization
// SLED4C serial display function Prototypes
void send_byte(int DAT); // send byte value to SLED4C
void send_nib(int NIB); // send nibble value to SLED4C
void enable(void); // enable data entry into SLED4C registers
void disable(void); // write data into SLED4C registers & disable
// DS1620 & temp related function prototypes
void write_1620(byte cmd); // write to DS1620
void init_1620(void); // initialize DS1620
void read_temp(void); // read temp from DS1620
void convert(void); // convert C to F then to BCD for display
void ouch(void); // display OUCH when >= high temp setpoint
char toBCD(char bin_val); // conversion to BCD
// DS1307 function prototypes
void set_time(void);
void read_time(void);
char read_byte(char addr);
void write_byte(char addr, char value);
//EMIC text-to-speech module function prototypes
void say_time(void);
void say_temp(void);
void setup_EMIC(int vol, int pitch);
int ds1307_regs[DATE_TIME_BYTE_COUNT];
as you can see all the registers are defined in the .h file, The main calls the init function, which then calls several other functions. including set_time, when the time is set it isn't referenced again, instead read_time is which is my where my problem lies. I need to somehow get that information that the battery backup stores in the DS1307 RAM into the PIC when I turn VCC back on.
I tried using an if statement to get it to work but was unsuccessful, I deleted that build so I don't have it anymore, psudocode of it though was
something like
in the init function above
if ds1307_regs[SECONDS_REG] == 0x7f
read_time
else set_time
that totally flopped though |
mcnscott2
Posted: Sat Apr 14, 2007 8:12 pm |
What I would really like to do is test this program on the MPLAB simulator, but I have no clue how I would even go about it. I've tried reading the manual and looking at the examples but they are somewhat confusing. |
jecottrell
Posted: Sun Apr 15, 2007 12:52 am |
What type of back-up battery are you using?
You should be able to program your PIC with the code as you have it. Every time you re-apply power or restart the PIC it is, obviously, going to reset the time to what ever you have written in your code. To handle this, just update your time in your code to something in the near future, program your PIC, and then power it up at the time you have programmed in your code. Recompile the code with the set_time() line commented out of the init function. Reprogram the PIC with the new code and the ds1307 should still be keeping time from your initial programming (that is if you have the correct battery connected correctly.)
Quote: | instead read_time is which is my where my problem lies. |
I think your problem lies with either the incorrect battery or your misunderstanding of how to get the time set in the ds1307 and then not change it with future resets.
Quote: | I need to somehow get that information that the battery backup stores in the DS1307 RAM into the PIC when I turn VCC back on.
No, nothing gets stored in the RAM unless you put it there. The RAM is for program data that you want the ds1307 to hold between power applications NOT for time information. The ds1307 will merrily keep on clicking away and keeping time once the CH register is set to 0 and power is applied (either Vdd or Vbackup.)
So, to solve your problem, you need to:
Use the correct battery (a 3V lithium).
Get the time set and CH register set to 0 (you do this with the code that you have posted.)
Reprogram the PIC to NOT reset the time with each reset.
Good luck,
John |
mcnscott2
Posted: Sun Apr 15, 2007 7:59 am |
Thanks for your responses,
The battery I'm using is a 3 volt lithium battery, I've tested it and it's putting about about 2.8 volts right now, and it is keeping time great. |
jecottrell
Posted: Sun Apr 15, 2007 8:26 am |
Quote: | it is keeping time great. |
Can you clarify what the problem is, and exactly what you do to get that to happen?
From your previous explanation it sounded as though the ds1307 wouldn't keep time if you commented out set_time().
John |
mcnscott2
Posted: Sun Apr 15, 2007 9:12 am |
The DS1307 keeps time good when the power is on for the entire circuit.
When I turn the power off the backup battery keeps the time the clock was at just when it was turned off. I have the program set per your directions
so for example
a. I turn on the clock it's 21:59
b. wait for about ten minutes clock says 22:09
b. turn off the clock (it's now on battery backup)
c. reprogram the PIC real quick to comment out set_time function
d. plug PIC back into circuit and turn it on
e. clock says 22:09 so I know the battery backup is working
f. run the clock for another 10 minutes time says 22:19
g. turn off the clock for ten minutes time should be 22:29 when I turn it on
but it still says 22:19
That last part is where I'm having difficulty |
jecottrell
Posted: Sun Apr 15, 2007 10:25 am |
Only thing I can think of just now is to do "h." for me and tell me what happens.
Do all your a-g items again.
c. & d. No hurry here. Take a few minutes and see if that changes the out come.
h. Wait ten minutes and see if it increments to 22:19 from 22:29 (i.e. make sure the clock really is running on the second power-up.)
What sort of power supply are you using? Do you have large Caps on the board? (I'm wondering if the Caps are some how powering the ds1307 instead of the backup battery... and giving erroneous indications of what's happening?) How do you remove power from the circuit, a switch, pull a power connector?
I would tend to default to a known good ds1307 driver to see if it is a software or hardware problem. There are several in the code library. I've never had problems with the ds1307 when using the CCS or other folk's drivers.
What you should really do is stop chasing your tail here and write a simple test program using a good ds1307 driver to confirm the RTC's correct operation. Trust me, the time it will take to write that code will most likely be a lot less than buggering around with some one else's code. I tend to procrastinate and avoid low level debugging like that too, but I always am relieved when I do it and the problem pops right out at me. It will also get you into the driver code and help you understand what's going on.
Try this one:
http://www.ccsinfo.com/forum/viewtopic.php?t=23255
John |
mcnscott2
Posted: Sun Apr 15, 2007 11:47 am |
John
Your note about the capacitor gave me an idea and I did a bit of research I aways put a .1uF cap between ground and an IC well you can't do this with the DS1307. When I turned the power off the energy from the battery back to the cap was causing power to to bounce back and forth between the cap and the battery, not causing the oscillator to operate. I took out the cap hooked to the DS1307 and problem solved!
Scott |
jecottrell
Posted: Sun Apr 15, 2007 12:08 pm |
Scott,
Didn't quite understand your original and final configuration...
Original (problem):
Vdd-->0.1uFcap(to gnd)-->ds1307Vcc
And...
+3V Lithium---> 0.1uFcap(to gnd)-->ds1307Vbat
Final (operates normally):
And
+3V Lithium-->ds1307Vbat
I've never had problems with decoupling caps on the supply pins. I've never put them on the battery backups.
John |
