Can CCS development board
Ospite
PostPosted: Wed Apr 11, 2007 3:55 am     Reply with quote
Someone can tell me clock speed 2510 and pic clock speed
because i want make by myself this board for simple use.
I don't have information about can speed that i can have if
I use example in compiler...
Thanks in advance
PostPosted: Wed Apr 11, 2007 11:25 am     Reply with quote
Go to the web page for that product and click on the picture of the board
to enlarge it.
http://www.ccsinfo.com/product_info.php?products_id=CANbuspb
You can then read the frequency of those two crystals -- it's etched on
the top of the crystals.
Ospite
Crystal frequency
PostPosted: Thu Apr 12, 2007 3:55 am     Reply with quote
Thanks,
My interesting is node B and i see 20Mhz Crystal that i thinks is
for 2510 /2515 but Crystal for PIC ?
It's the same clock or is in bottom layer?
PostPosted: Thu Apr 12, 2007 9:03 am     Reply with quote
You can find the PIC frequency by looking at the CCS example file for
node B. Here's the location of that file:
c:\program files\picc\examples\ex_can_ccs_b.c
In that file it says the PIC's clock frequency is 2.5 MHz.
#include <16F876.h>
#fuses HS,NOPROTECT,NOLVP,NOWDT
#use delay(clock=2500000)
That's not a normal frequency, so where do they get it ?
The answer is, from the CLKOUT pin of the MCP2510.
If you look in the MCP2510 data sheet in the Oscillator section, they say
that the divisor for the CLKOUT pin defaults to 8, upon power-on reset.
20 MHz / 8 = 2.5 MHz
That explains where the 2.5 MHz for the PIC comes from.
Ospite
Crystal frequency
PostPosted: Thu Apr 12, 2007 10:21 am     Reply with quote
Many Many thanks,
after you explain all is clear and now i can made my board.....
It's a pleasure have a "friend" like You.
