meereck
wireless network - more listeners |
Posted: Tue Apr 10, 2007 1:16 pm |
Hello everyone,
I would like to build a device which communicates with others via a wireless network. Prerequisite is a possibility of more devices receiving a packet (no point to point).
What network and peripherals for a PIC are suitable?
thank you,
Best regards M. |
rnielsen
Posted: Tue Apr 10, 2007 2:54 pm |
http://www.maxstream.net/products/xbee/xbee-pro-oem-rf-module-zigbee.php
I've used these modules in a couple of projects and they are fairly inexpensive. They have the ability to, in default mode, act as a serial cable between two devices. They can, also, be made to be a point-to-multipoint or multipoint-to-multipoint device. I had to get a MAX3371 interface part to convert the PIC's 5V signal to the XBEE's 3.3V signals. It took me a couple of calls to their Tech Support to figure out how to do the point-to-multipoint but now that I've got the hang of it it's fairly simple to make things work.
Ronald |
meereck
Posted: Wed Apr 11, 2007 5:27 am |
thank you very much for an interesting reply.
I did some background reading about ZigBee. The problem is that I need to send a data to all devices in range of a sender and I don't want to be concerned with addresses, since I just need something like a broadcast packet. In other words I just need to send a packet to everyone who is able to receive it.
Therefore I need something which is not based on addressing.
Is the ZigBee capable of this?
Hope I explained it clearly.
cheers M. |
Foppie
Joined: 16 Sep 2005 Posts: 138 Location: The Netherlands
Posted: Wed Apr 11, 2007 5:44 am |
The Maxstream modules are able to broadcast. I believe this is only in the multi-point-to-point version but it might also work in the zigbee version. (hardware is the same for both function, you only need to flash the chips with new software to support the different versions).
Which ever version it is that supports the broadcast, you might find it usefull.
Hope this helps, Jos |
jecottrell
Posted: Wed Apr 11, 2007 6:25 am |
Actually, with the Maxstream radios, there is no need to reflash the radios for the configuration you describe. A simple protocol in your PICs would allow for the reception of the broadcast packet.
The X-CTU software to reflash the radios is easy to use and allows for changing the default settings like: BAUD, ID's, channels, etc.
I would recommend them highly and they would be very suitable for your application.
John |
Foppie
I just looked it up in the maxstream zigbee manual and it says it has the broadcast functionality available.
So you can use the maxstream zigbee modules. |
kd5uzz
