Some help with a VFD Please
JeffLewcock
PostPosted: Tue Apr 10, 2007 1:57 pm     Reply with quote
Hi All
I need some help !
I have a 16x1 VFD display can anyone give me some ideas on how to talk to it ?
The data sheet calls the interface a Sync Serial is this the same as SPI ? or is it just simalar ?
The VFD datasheet is here www.jefflewcock.com/au1613-K2SS-04.pdf
The interface (VFD) chip datasheet as this appears to have more info is here www.jefflewcock.com/OKI_C1937_01.pdf
Any help would be appreciated !
Jeff
PostPosted: Tue Apr 10, 2007 2:51 pm     Reply with quote
Page 9 of the data sheet has the timing diagrams. It shows 8 clocks,
and a data line. Therefore, you can use the hardware SPI module in
the PIC.
Also on page 9, it gives a spec for the data setup before the falling
edge of SCLK. Therefore the VFD samples the data on the falling edge.
It also shows that SCLK idles at a low level. Based on that information,
you can identify the correct SPI mode from the following web page.
It's SPI mode 1.
http://www.totalphase.com/support/articles/article03/#modes
The maximum frequency of SCLK is rather low, at 500 KHz max.
So you will need to use the appropriate divisor in your setup_spi()
statement, based on your PIC's oscillator frequency. For example,
with a 4 MHz crystal, you can use the divide-by-4 divisor to get 250 KHz.
(1 MHz instruction clock / 4 = 250 KHz SCLK).
Your SPI setup would look like this:
#include <16F877.H>
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#define SPI_MODE_0_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_0_1  (SPI_L_TO_H)
#define SPI_MODE_1_0  (SPI_H_TO_L)
#define SPI_MODE_1_1  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
setup_spi(SPI_MASTER | SPI_MODE_0_1 | SPI_CLK_DIV_4);
Now you can begin to write the driver for the VFD display. You'll need
to create the POR reset pulse (see the data sheet for the required pulse
width). You also need to wait for a required amount of time after the
reset pulse is done. Then you can use the spi_write() function to send
commands and data to the chip. Note that you must wait for the
required "command processing time" after sending a command.
You can find the delay time in the data sheet.
JeffLewcock
PostPosted: Tue Apr 10, 2007 3:40 pm     Reply with quote
Excellent
Thanks very much; I think I understand !
I'll give it a try tomorrow (its 2240 here)
Thanks Again
Jeff
