New project: LCD module drivable via Bluetooth
Christophe
PostPosted: Tue Apr 10, 2007 12:55 am     Reply with quote
for a new project I'm looking for a LCD module that can be driven via BLuetooth, via a PC. So actually serially.
Normally a LCD module is only drivable via a microcontroller via it's data and control lines. I'm looking for a module that has it all, a soort of screen/LCD that you can control via BT.
If this does not exist, this is going to be my next project; a BT module, probably some PIC µC and an LCD module.
Anyone has got some ideas?
PostPosted: Tue Apr 10, 2007 1:06 am     Reply with quote
See this thread on the CrystalFontz LCD forum:
http://www.crystalfontz.com/forum/showthread.php?t=3305
Christophe
PostPosted: Tue Apr 10, 2007 5:13 am     Reply with quote
So I can assume that module does not exist as an end product. Also can't find any information on the internet..
libor
PostPosted: Tue Apr 10, 2007 7:49 am     Reply with quote
I think this solution exists in two separate products that one could combine:
- BT modules acting transparently as a serial RS232 wire.
- an LCD module with an (add-on) RS-232 interface.
anyway, it will be much cheaper and edifying if you would build your own.
Christophe
PostPosted: Tue Apr 10, 2007 8:36 am     Reply with quote
Does anyone have good experience with data serial bluetooth modules ?
kevcon
PostPosted: Tue Apr 10, 2007 8:50 am     Reply with quote
We did a project that worked out quite well with National's LMX9820A part.
http://cache.national.com/pf/LM/LMX9820A.html
We are currently working on a redesign with the much cheaper and smaller LMX9830 part along with a PIC18F65J10
http://cache.national.com/pf/LM/LMX9830.html
Kevin
libor
PostPosted: Tue Apr 10, 2007 8:59 am     Reply with quote
I have tried these BT v. 2.0 modules: Link: Bluegiga , the WT12 model. they work with simple alphabetic ASCII commands, and also have a data transparent operating mode.
NB: these modules are quite small in size, fine SMD soldering (and some fine prototype PCB manufacturing) is required, so the hardware part is not for a beginner hobbyist. (i suggest to look for an evaluation board, or a more ready-assembled end-product.)
Christophe
PostPosted: Wed Apr 11, 2007 12:59 am     Reply with quote
Thanks for your input, I'll sure look at your implementations. I took a quick peak at the first and that seemed to be a BGA chip?
Atm students here are implementing this one: http://www.ezurio.com/products/bism/
I don't know if there are any cheaper solutions as this? This one costs 50€ per piece. It also has audio which is not needed for our application. Anyone has got experience with these modules?
