problem of RS232 , thanks for all the help coming...
Goto page 1, 2  Next
progCCSC
PostPosted: Fri Apr 06, 2007 1:33 am     Reply with quote
I use this program to receive a data and then transmit it for 10 times, and I have this result:
I transmit to PIC18F452 from a terminal PC these datas:
0 1 2 3 4 5 6 7 8 9
I got :
38 39 3A 3B 3C 3D 3E 3F 38 39
and LCD affiche: -56 -55 -54 -53
#include <18F452>
#fuses HS, NOPROTECT, NOWDT, NODEBUG, NOLVP, PUT
#use rs232(baud=115200,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#include <LCD.c>
     int8 data[10],i,j;
    for(i=0;i<10;i++)
        data[i]=getc();
        putc(data[i]);
        printf(lcd_putc,"%d",data[i]);
progCCSC
up
PostPosted: Fri Apr 06, 2007 3:19 am     Reply with quote
up up!! sos!
PostPosted: Fri Apr 06, 2007 9:08 am     Reply with quote
How is the connection to the PC made?. Have you tested a much simple 'Hello world' type transmission only? Does this work?.
Humberto
PostPosted: Fri Apr 06, 2007 9:32 am     Reply with quote
include <18F452>
#include <LCD.c>
int8 data[10],i;
     i=0;
     do
        data[i]=getc();
        putc(data[i]);
        i++;
       }while(i<10);
    for(i=0;i<10;i++;)
Humberto
PostPosted: Fri Apr 06, 2007 10:00 am     Reply with quote
Yes. This avoids the timing problem, but the timing, shouldn't affect the first couple of bytes, hence my feeling that there is a hardware problem as well...
PostPosted: Fri Apr 06, 2007 10:26 am     Reply with quote
ProgCCSC, which compiler version are you using?
How is the PC connected to the PC? Are you using an inverter chip like the MAX232?
progCCSC
PostPosted: Mon Apr 09, 2007 2:16 pm     Reply with quote
I used max232 for the connection, and I tested what you said, but it didn't work Sad
progCCSC
thanks
PostPosted: Mon Apr 09, 2007 2:24 pm     Reply with quote
to Humberto: thanks very much! I will try it.
to ckielstra: I use version 3.187 with MPLAB v7.41, is there some problem with it?
to every, as terminal PC, what you are using?..... I use "Free Serial Port Monitor."
PostPosted: Mon Apr 09, 2007 2:28 pm     Reply with quote
This schematic shows an 18F452 connected to a MAX232A.
You don't need CTS and RTS. You just need Tx, Rx, and Ground.
They show the connections to a DB9F connector. Then just use
a straight-through cable to connect the board to your PC.
(The cable is wired with pin 1 to pin 1, pin 2 to pin 2, etc).
http://www.picbook.com/bookinfo/QwikFlash.pdf
Note that a MAX232 uses 1 uF capacitors. The MAX232A uses .1 uF caps.
PostPosted: Mon Apr 09, 2007 3:04 pm     Reply with quote
OK.
Receiving '38', for '30' sent (a ASCII zero, is x30), implies that the incoming signal is being sampled slightly too early. If this was what was being seen, I'd be looking at the timing error. However the display value of -56, corresponds to 0xC8, which doesn't agree with a timing error. Effectively, looking at the bit patterns concerned, organised in the order the UART sees them, you get:
0x30 10000011001
0x38 10000111001
0xC8 10000101011
Now you can see that while the second, could potentially 'happen', if the system was just fractionally early when it sampled the sixth bit, it'd have to be at normal times, or latter to still get the next two '1's. The third combination though, just doesn't work, having an extra '0' inserted.
I'd start with a much simpler test. First verify _everything_ (clock frequency - program an output pin to toggle at an interval, and check it with an oscilloscope, or stopwatch), then all the connections - is the ground good etc. etc.. Triple check baud rate settings, word length, etc.. Then do a simple program, to send 0xAA 0x55. The hex value of the bytes seen at the PC, may make it obvious what is going on.
progCCSC
still...
PostPosted: Tue Apr 10, 2007 2:12 am     Reply with quote
thank you very much for your help, I haven't resolu my problem and I have also a strange problem , I set baud rate=115200, but if I set also baud rate=115200, there is noting received. I have to set baud rate =9600 for the terminal PC.
Ttelmah wrote:
OK.
0x30 10000011001
0x38 10000111001
0xC8 10000101011
PostPosted: Tue Apr 10, 2007 2:37 am     Reply with quote
Whoa a sec. What you are saying here, disagreed with what you have _posted_ You talk about receiving a particular pattern of data, with code working at 115200bps, but now you arwe saying you are working at 9600bps....
The figures _must_ be the same at both ends. If you need to set the PC to 9600bps to get anything received, then set the PIC code to the same rate. Triple check your crystal. Are you _sure_ this is 20Mhz, and is actually running at 20MHz. Put an LED on a single pin (with a current limiting resistor), and have a program like:
main {
   while (TRUE) {
       output_toggle(whatever_pin_the_LED_is_on);
Does the LED flash on for one second, off for one second, etc.. If not, then your crystal is not running at 20Mhz.
One possibility, is that your wiring, is not capable of working at 115200 bps.
progCCSC
PostPosted: Tue Apr 10, 2007 7:01 am     Reply with quote
to Ttelmah: thank you for your patience.
Now, Yes, I have done a error, I will expicate it now.
My clock is 12 MHz,--------I'm sure it's right, so 20MHz wasn't right. I have changed it to 12MHz, but it did not use for settle the problem.
What I have said there 1h ago wasn't clear.
Now, I use this programme
#include <18F452>
#fuses HS,NOWDT,NOPROTECT,NOPUT,BROWNOUT,NOLVP,CCP2C1,NOSTVREN,NOWRT,NOCPB,NOEBTRB,NODEBUG
#use delay(clock=12000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#include </drivers>
int8 data[10],i;
     i=0;
     do
        data[i]=getc();
        putc(data[i]);
        i++;
       }while(i<10);
    for(i=0;i<10;i++)
        printf(lcd_putc,"%c",data[i]);
Pour receive I use a terminal PC, I set 9600 baud rate as the program.
I transmit:
61 62 63 64 30 31 32 33 34 35 36 37 61 62 63 abcd01234567abc
I received:
80 80 80 80 80 80 80 80 80 80 €€€€€€€€€€
progCCSC
PostPosted: Tue Apr 10, 2007 7:04 am     Reply with quote
I transmit:
It corresponds: abcd01234567abc
I received:
It corresponds: €€€€€€€€€€[/quote]
progCCSC
PostPosted: Tue Apr 10, 2007 7:11 am     Reply with quote
So if I change the clock to 20MHZ and the baud rate to 115200bps
#include <18F452>
#include </drivers>
int8 data[10],i;
     i=0;
     do
        data[i]=getc();
        putc(data[i]);
        i++;
       }while(i<10);
    for(i=0;i<10;i++)
I transmit:
61 62 63 64 65 67 68 30 38 39
It corresponds:   abcdegh089
I received:
61 62 63 6C 65 67 60 38 38 39
It corresponds:    abcleg`889
It seems that the parameter 20MHZ and 115200bps make the resultat the most close to what I want, its so strange
Goto page 1, 2  Next
Page 1 of 2
