MAX517 and PIC16F877
rblue
PostPosted: Sun Apr 08, 2007 5:34 pm     Reply with quote
hi guys i am using pic 16f877 and max 517 ... i have written a programme and it is giving an error can any body check what i did wrong:
#include <16F877.h>
#device ICD=TRUE
#device ADC=10 // Use 10bits ADC
#use delay(clock=20000000) // 16Mhz Crystal is Used
#include <MAX517.c>  //Call for MAX517.c function
#define TRIGGER = PIN_E0
#define SAMPLE1 = PIN_C4
#define SAMPLE2 = PIN_D2
#define SAMPLE3 = PIN_C5
int1 data_end = 0;
   set_tris_d( 0xff );
   set_tris_c( 0xbf );
   set_tris_e( 0xff );
Begin:
if (TRIGGER)//<-- A numeric expression must appear here what i did wrong cant find out
      data_end = 0 ;
      goto  Begin ;
   if (!TRIGGER && !data_end)
      if (!SAMPLE1)
               output_high(PIN_A0); //LED ON
               write_dac(0xFF);     //DAC output 5V
            delay_ms(5000);    //Delay
            output_low(PIN_A0); //LED OFF
            write_dac(0x00);   //DAC output 0V
         data_end = 1 ;
            if (!SAMPLE3)
         data_end = 1 ;
      goto Begin ;
Looking forward for help
Rblue
PostPosted: Sun Apr 08, 2007 5:42 pm     Reply with quote
change to
#define TRIGGER  PIN_E0
rblue
PostPosted: Sun Apr 08, 2007 10:13 pm     Reply with quote
thanx.............. its now working fine
Laughing
