mcnscott2
need a bit of help with this snippet of code |
Posted: Sun Apr 08, 2007 8:36 pm |
I'm still working on this time and temp clock, I'm trying to make it say the time and temp on the quarter hours now, so I've modified the code some. The problem I'm having is the program works when the first designated time is reached, x:00, x:15, x:30, x:45, however, it won't work again. The clock and temperature keep running fine, however my say_time, say_temp functions won't work. Any clues?
Code: | void Main(void)
int announce=0; // holds # of time/temp announcements
init(); // initialize I/O & peripherals
while(1) // loop forever
read_time(); // read & display DS1307 time
read_temp(); // read & display DS1620 temp
// announce time/temp on roll-over to 00, 15, 30, 45 minutes
if(ds1307_regs[MINUTES_REG]==0x00 || ds1307_regs[MINUTES_REG]==0x15
|| ds1307_regs[MINUTES_REG]==0x30 || ds1307_regs[MINUTES_REG]==0x45)
if(!announce) // say time & temp only if announce=0
say_time(); // say the current time
delay_ms(3000); // delay 3 seconds
say_temp(); // say the current temperature
announce +=1; // increment announcement counts
} // end inner if
} // end outer if
if(!ds1307_regs[MINUTES_REG]==0x00 && !ds1307_regs[MINUTES_REG]==0x15
&& !ds1307_regs[MINUTES_REG]==0x30 && !ds1307_regs[MINUTES_REG]==0x45)
announce=0; // clear announcements until it's time
} // end while loop
} // end main |
jecottrell
Posted: Sun Apr 08, 2007 8:48 pm |
Sure you don't mean:
int1 announce=true; // holds status of announcements
if(announce) // say time & temp if enabled
announce = false; // disable announcements
} // end inner if
announce=true; // enable announcements
Also, I use parentheses to excess to eliminate any problems with order of operations errors on my part.
John |
mcnscott2
Posted: Sun Apr 08, 2007 9:09 pm |
I'll give that a shot anything is better than pulling my hair out |
jecottrell
Posted: Sun Apr 08, 2007 9:29 pm |
If you look at the order of operations in the compiler manual the ! operator is evaluated before the &&. Also, what you were trying to express was:
Code: | ((ds1307_regs[MINUTES_REG]!=0x00) && (ds1307_regs[MINUTES_REG]!=0x15)
&& (ds1307_regs[MINUTES_REG]!=0x30) && (ds1307_regs[MINUTES_REG]!=0x45)) |
... I think.
John |
mcnscott2
Posted: Sun Apr 08, 2007 9:31 pm |
I gave that a shot, and tried to change the false true statements in a couple places but nothing worked, still says time and temp on the quarter hour then never again, I changed my times though 30, 31, 32 instead of 15, 30, 45. Here is the original code by Bruce Reynolds, I've confirmed this works. Every hour on the hour it says the time and temp.
It's got me baffled too John, thanks for the help I can't think of another way to put it in the code my psuedocode is:
1. if the time is x:00 or X:15 or X:30 or x:45
2. say time and temp
3. if the time and temp announcement has gone off
4. don't say it again until the next quarter hour.
(I messed with the || in place of the && for the second statment of the code and it kept saying the time and temp every 5 seconds instead of once.
// announce time/temp on roll-over from 59 to 00 minutes
if(ds1307_regs[MINUTES_REG]==0x00)
if(!ds1307_regs[MINUTES_REG]==0x00)
jecottrell
Posted: Sun Apr 08, 2007 9:43 pm |
Try this. I think you have an order of operations problem...
if((ds1307_regs[MINUTES_REG]==0x00) || (ds1307_regs[MINUTES_REG]==0x15)
|| (ds1307_regs[MINUTES_REG]==0x30) || (ds1307_regs[MINUTES_REG]==0x45))
} // end inner if
I forget what format the values are in the ds1307_reg. You could have problem with that? |
Posted: Sun Apr 08, 2007 10:36 pm |
You may have problems with operator precedence, but your main
problem is that you've stuck a "0x" in front of all your time values.
This turns 15 minutes into 0x15 minutes, which is actually 21 minutes.
That's why it only works with 0x00. Even as a hex value, 0 is still 0. |
mcnscott2
Posted: Sun Apr 08, 2007 10:59 pm |
I know the hex numbering looks strange but it's not hex really, I have to put in the decimall minutes I want for the function to work, instead of 1E it has to be 30, 45 instead of 2D etc. Here is the code for the function that actually reads the time.
Code: | // read time & date from DS1307
void read_time(void)
i2c_start();
i2c_write(WRITE_CNTRL);
// start i2c read at seconds register
i2c_write(SECONDS_REG);
i2c_start();
i2c_write(READ_CNTRL);
// read the 7 bytes from the ds1307. Mask off the unused bits
ds1307_regs[SECONDS_REG] = i2c_read() & 0x7f;
ds1307_regs[MINUTES_REG] = i2c_read() & 0x7f;
ds1307_regs[HOURS_REG] = i2c_read() & 0x3f;
ds1307_regs[DAY_OF_WEEK_REG] = i2c_read() & 0x07;
ds1307_regs[DATE_REG] = i2c_read() & 0x3f;
ds1307_regs[MONTH_REG] = i2c_read() & 0x1f;
ds1307_regs[YEAR_REG] = i2c_read(0);
i2c_stop();
enable(); // enable SLED4C data entry
send_byte(0b11000001); // all banks HEX decode
disable(); // write config value into config register
send_nib(0x00); // DIM display + DP's off
send_byte(ds1307_regs[HOURS_REG]); // display hour on banks 5/4
send_byte(ds1307_regs[MINUTES_REG]); // display minutes on banks 3/2
send_nib(0x02); // turn colon on
disable(); // write data into display registers
delay_ms(2000); // wait 2 seconds between temp & time updates
Posted: Sun Apr 08, 2007 11:19 pm |
You must be leaving the minutes in the BCD format used by the DS1307.
I made a test program and put in the same fix for operator precedence
that jecottrell suggested. It seems to work. It displays the time every
15 minutes. I didn't test it with all time values. You might test it further.
Quote: |
Time = 00
say time
Time = 01
Time = 15
say time
Time = 16
Time = 30
say time
Time = 31
Time = 45
say time
Time = 59
Time = 00
say time
Time = 01
Time = 15
say time
Time = 16
Time = 30 |
Here's the test program. Tested with vs. 3.249 in MPLAB simulator.
#include <16F877.h>
#fuses XT, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP
int8 ds1307_regs[8];
#define MINUTES_REG 1
void say_time(void)
printf("say time\r");
void say_temp(void)
//printf("say temp\r");
// Return some representative time values.
static int8 index = 0;
int8 time[8] = {0x00,0x01,0x15,0x16,0x30,0x31,0x45,0x59};
ds1307_regs[MINUTES_REG] = time[index++];
index &= 0x07;
void read_temp(void)
//printf("read temp\r");
int announce=0;
// init();
read_time();
printf("Time = %x\r", ds1307_regs[MINUTES_REG]);
read_temp();
if(!announce)
say_time();
delay_ms(30);
say_temp();
announce +=1;
if((ds1307_regs[MINUTES_REG] != 0x00) &&
(ds1307_regs[MINUTES_REG] != 0x15) &&
(ds1307_regs[MINUTES_REG] != 0x30) &&
(ds1307_regs[MINUTES_REG] != 0x45))
announce=0;
mcnscott2
Posted: Sun Apr 08, 2007 11:21 pm |
I'll give it a try thanks !
well your code worked for me, but it had me perplexed because I was sure, I had tried that operator arrangement many times, I finally figured out the problem.
I was trying to save time so instead of waiting 15 minutes for the message I had my time parameters set up at x:30, x:31,:x32, x:33 sooo.... The program never got a chance to play the next message because it saw that if the time was equal to x:31 it must have already played the message so it never played it, same for when the time got to x:32, then x:33. I can finally go to sleep! thanks everyone! |
Posted: Mon Apr 09, 2007 2:33 am |
Well done.
This little 'catch', is very common. It is why (for instance), you will see people who are aware of this, using an interrupt 'counter', and coding like:
(in the interrupt)
if (counter) --counter;
(in the main)
if (!counter) //operations here to be done when counter==0
Rather than checking for a counter getting 'to' a particular value. The risk of missing a particular 'count', gets even higher, when there are multiple asynchronous interrupts enabled, and this can be a pig to discover...
