printf %3.1w leading zeros
iw2nzm
PostPosted: Fri Apr 06, 2007 5:50 am     Reply with quote
Hi!
I need to print an integer in this format: 00.0
I use printf %3.1w and it works but it doesn't print the leading zero. For example:
value = 4.2 -> output = 4.2
I'd like output = 04.2
How should I fix it?
Marco / iw2nzm
PostPosted: Fri Apr 06, 2007 7:05 am     Reply with quote
Two things. On all the numeric formats, you add a leading 'zero' to the format, to make the extra leading spaces become filled with zeros. However as specified, you have no leading spaces, since your field 'width', matches the output (4.2, is three characters wide).
So you need to use:
printf("%04.1w",val);
To output a four character wide field, with a leading zero.
iw2nzm
PostPosted: Fri Apr 06, 2007 8:09 am     Reply with quote
So you need to use:
Thank you very much, now it works fine!
Marco / iw2nzm
future
PostPosted: Fri Apr 06, 2007 1:10 pm     Reply with quote
I noticed a big speed impact using %4.1w over %u02.%u1 showing the quotient and rest of a division.
Maybe the compiler uses 16/16 in its internal routines.
PostPosted: Fri Apr 06, 2007 2:30 pm     Reply with quote
You will notice, that %w, does not need a 'L' specifier. it assumes that you will be using a 'long', since otherwise the range is so limited.
