Freddie
Break up float to 2 bytes |
Posted: Thu Apr 05, 2007 5:49 am |
I want to save a float as 2 bytes. One byte representing the part before the decimal, one representing the part after the decimal.
How can I extract the parts into seperate bytes? |
Posted: Thu Apr 05, 2007 7:51 am |
Obviously, you will be limited to numbers 255 and below.
If you simply take:
int main;
float val;
val=123.45;
main=val;
You will get the part in front of the decimal place stored in the integer.
Now, to do the whole thing, you can use:
int decimal;
int main;
float val;
float decimalf;
val=123.45;
decimal = 100*modf(val,&decimalf);
main=decimalf;
However 'beware' of the inaccuracies in this...
int main;
int decimal;
float val;
val=123.45;
main=val;
decimal=(val*100)-(main*100L);
Will probably be faster, and may be better.
I have to ask, 'why have a float at all'?. Consider using a larger scaled integer in the first place. Makes arithmetic much faster, and makes this a lot easier...
