Conditional ternary operator ?:
EdWaugh
PostPosted: Wed Apr 04, 2007 5:12 am     Reply with quote
Hi everyone,
I'm trying to use this code on v3.245 but I get a 'bad expression syntax' error. Can anyone suggest what I'm doing wrong?
fprintf(rda2_strm, "I have %d apple%s\n", apples, (apples == 1) ? "" : "s");
cheers
ed
kender
PostPosted: Wed Apr 04, 2007 5:40 am     Reply with quote
If I understand everything correctly, the expressions left of ? in ?: should be numeric (char, int, float, etc).
EdWaugh
PostPosted: Wed Apr 04, 2007 6:03 am     Reply with quote
aha, that does seem to compile but I'm sure the way I'm trying to use it is legitimate in C.
I found that this compiles:
printf("I have %d apple%s\n", apples, (apples == 1) ? ("") : ('s'));
where "s" is traded for 's'. Is it because the first way is using pointers to constant data which v3 doesn't support?
EdWaugh
PostPosted: Wed Apr 04, 2007 6:38 am     Reply with quote
actually although that code compiles now it just spits out garbage when it gets executed...
Nevermind, maybe I'll just have to do it the long way!
PostPosted: Wed Apr 04, 2007 11:53 am     Reply with quote
I think it's because CCS doesn't like the constant strings. If you change
it so the strings are in ram arrays, then it works. Example:
#include <16F877.H>
#fuses HS, NOWDT, BROWNOUT, PUT, NOLVP
int8 apples;
int8 no_char[1] = 0;
int8 s_char[2] = "s";
apples = 6;
printf("I have %d apple%s\n", apples, (apples == 1) ? no_char : s_char);
PostPosted: Wed Apr 04, 2007 12:36 pm     Reply with quote
%d, expects to receive a single byte numeric value, not a 'string'. The syntax is not correct C. However on many compilers (where strings are held in RAM), it may result in the value of the first byte in the string being printed (most though will just complain). The single inverted commas, give a character constant, which does have a numeric value. However you need to translate both values into this form.
PostPosted: Wed Apr 04, 2007 12:42 pm     Reply with quote
The %d is getting 'apples' as the variable.
