No source code in MPLAB
RossJ
PostPosted: Tue Apr 03, 2007 9:52 pm     Reply with quote
I have recently begun using v4 (now 4.031), and am unable to view the C source code under MPLAB when I import the COF file. When I view program memory, I just see the assembly divided up by source file. But no actual source listing. It worked fine with 3.249.
Any ideas? I am using MPLAB 7.52.
/Thanks, Ross.
PostPosted: Tue Apr 03, 2007 10:08 pm     Reply with quote
People on the Microchip forum suggest that you should un-install 7.52
and go back to MPLAB vs. 7.40. See these two threads:
http://forum.microchip.com/tm.aspx?m=238076
http://forum.microchip.com/tm.aspx?m=227821
You can get vs. 7.40 at the link below. It's on the right side,
in the "32-Bit Windows" section.
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en023073
