woh format carateres to see in lcd
gaviao
PostPosted: Tue Apr 03, 2007 2:06 pm     Reply with quote
i am using this code to read the adc value and print in the lcd and serial port, on the serial port the formatation is ok, but on the lcd i can't see the right numbers.
int32 temp;
temp = (int32) read_adc();
printf("Valor A/D S0 = %lu --> Temp0= %lu.%lu C \n\r ",temp, temp/10, temp%10); // its ok
printf(lcd_putc,"Temp0: %ld.%ld C",temp/10, temp%10); // wrong formatation??
i use the generic ccs driver for lcd
Smile thank you
PostPosted: Tue Apr 03, 2007 2:16 pm     Reply with quote
1. Post the good output and the bad output (on the LCD), so we can see it.
2. Does your LCD display any output ?
Try a simple test program for your LCD:
http://www.ccsinfo.com/forum/viewtopic.php?t=25994&start=3
3. Also post your compiler version.
gaviao
PostPosted: Wed Apr 04, 2007 8:06 am     Reply with quote
I find the problem, is in the lcd lib, in the method void lcd_putc( char c),
i have 2 lines comment :p
Embarassed
thank you, PCM programmer Smile
