FMOD() utilisation - Division a float by a float
Joseph
PostPosted: Mon Apr 02, 2007 2:01 pm     Reply with quote
Hello !!! excuse for my english but I'm a french boy....
I'have got a problem, I want to make a simple division (Float by an another float) but impossible :
Here my script in few lines....Please help me....
#include <16F877A.h>
#include "math.h"
#include "float.h"
void main (void)
float result;
float val1=150.0;
float val2=0.54;
result=fmod(val1,val2); // At this line, the Step mode open the
// source code of "math.h" and stop
// the execution
I don't understand because the syntaxe is the same than CCS_manual.pdf
thanks before
PostPosted: Mon Apr 02, 2007 2:09 pm     Reply with quote
I tested your code with compiler vs. 3.249, and with MPLAB vs. 7.20.
It worked OK. I pressed the F8 key, to "Step over". It goes to the
fmod() routine in math.h, and then it goes to the floor() routine, and
then it exits math.h and goes back to the main() code.
What is your compiler version ? What is your version of MPLAB ?
Are you pressing the F8 key ?
kevcon
What did you get for result?
I got 0.419998169
Joseph
PostPosted: Mon Apr 02, 2007 2:18 pm     Reply with quote
Ohhhhhhh oki
For me when I am in the code source of math.h its an error..... so the script is ok....thanks
But an another question.....150 / 0.54 = 277.77 and not 0.41 Why ???
I am a newbe.....
PostPosted: Mon Apr 02, 2007 3:33 pm     Reply with quote
Apparently fmod() is not very accurate:
http://support.microsoft.com/kb/57479
kevcon
PostPosted: Tue Apr 03, 2007 7:14 am     Reply with quote
I noticed that too, the result int this case should be 0.42 not 0.419998169
