ENGIMK Guest
problem with pic18f |
Posted: Thu Mar 29, 2007 1:59 pm |
i use pic18f2221 and pic c v 4.013
when i make array of int16 or int32 and try to read it it read false data
i do it in simulator and i found that either the data is shifted in ram or he read from the next address from the variable i want to read
i try pic c v 4.023 the same thing happen |
Posted: Thu Mar 29, 2007 2:09 pm |
Post a small test program. Then I can install that compiler version
and look at the problem. |
ENGIMK Guest
THERE IS THE CODE |
Posted: Thu Mar 29, 2007 2:13 pm |
#include <18F2221.h>
unsigned int32 step[3];
unsigned int32 remain[3];
unsigned int8 index;
for(index=0;index<3;index=index+1)
step[index]=10;
printf("index%d step=%lu\n",(byte)index, step[index]);
remain[index]=10;
printf("index%d remain=%lu\n",(byte)index,remain[index]);
output_high(pin_a0);
for(index=0;index<3;index++)
printf("index%d remain=%lu step=%lu\n",(byte)index,remain[index],step[index]);
output_low(pin_a0);
remain[index]=remain[index]-step[index];
if(remain[index] < step[index])
remain[index]=remain[index]+10;
I TRY IT ALSO ON PIC C V 3.249 BUT SAME THING HAPPEN
PRINTF SEND STEP=0 INSTEAD OF 10; |
Posted: Thu Mar 29, 2007 2:25 pm |
I compiled it with vs. 3.249 and ran it in the simulator for MPLAB vs. 7.20
and I got this:
index0 step=10
index1 step=10
index2 step=10
index0 remain=10
index1 remain=10
index2 remain=10
index0 remain=10 step=10
index1 remain=10 step=10
index2 remain=10 step=10
etc.
What version of MPLAB do you have ? |
ENG.IMK
Posted: Thu Mar 29, 2007 2:27 pm |
I USE PICSIMULATOR _________________ IMK |
Posted: Thu Mar 29, 2007 2:43 pm |
Here is their webpage, with screenshots at the bottom:
http://www.oshonsoft.com/pic18.html
I don't want to try to find or fix problems in their simulator.
I'm content to use MPLAB simulator. |
