I'm working on this project below, I'm curious though if I need to include the command #fuse MCLR for this project or not. The project has a reset button that takes the normally low MCLR pin high to reset the PIC, or is it not necessary to include this fuse?
Posted: Tue Mar 27, 2007 12:05 am
Look at the list of available fuse settings at the start of the
16F876A.H file.
Also look in the 16F876A data sheet, in the section called
"Special Features of the CPU". Look at the diagram of the
Configuration Word.
This will answer your question.
w2drz
Joined: 27 Dec 2006 Posts: 55 Location: Western New York - USA
Posted: Wed Mar 28, 2007 2:45 pm
In your hardware may wish to add a resistor of 330 ohm to the osc2 line,
this reduces crystal over drive.
