Serial communications between two PIC's
bestbuylvr
PostPosted: Mon Mar 26, 2007 12:38 pm     Reply with quote
I have a bit of really simple code I wrote up here trying to just make 2 PIC's talk back and forth to each other. I never really got to making any indicators (LED's) on the master 1st PIC because I can't really get the second to read the data sent from the first. I will post the code of both, and if anyone has any suggestions, I would appreciate any help.
PIC 1:
#include <18f452.h>
#include <protoalone_1.h>
#include <utility_1.c>
#include <stdlib.h>
#include <INPUT.C>
#use rs232(baud=2400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
main(){
while(1){
   int a, b;
delay_ms(2000);
   a=5;
   printf("%d", a);
   delay_ms(5);
   b = get_int();
   delay_ms(10000);
PIC 2:
#include <18f4520.h>
#include <stdlib.h>
#include <INPUT.C>
main(){
setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
      setup_psp(PSP_DISABLED);
      setup_spi(FALSE);
      setup_wdt(WDT_OFF);
      setup_timer_0(RTCC_INTERNAL);
      setup_timer_1(T1_DISABLED);
  output_bit(PIN_D0,0);
      output_bit(PIN_D1,0);
delay_ms(200);
      output_bit(PIN_D0,1);
      output_bit(PIN_D1,1);
      delay_ms(200);
while(TRUE){
   int a, b;
   a = get_int();
   if (a==5) {
   else {
   delay_ms(5);
   printf("%d", a);
   delay_ms(10000);
PostPosted: Mon Mar 26, 2007 1:14 pm     Reply with quote
Look at the source code for the get_int() function. It's in this file:
c:\program files\picc\drivers\input.c
get_int() calls the get_string() function. That function is looking for
a carriage return character to indicate the end of the string.
You're not sending one with your printf() statements. You need
to add \n after the %d, to do this.
Another thing is that you have these huge delays in your loops.
Also, you have two PICs that are not synchronized to each other.
So one of them could be in the middle of a huge 10 second delay
while the other one is sending characters. The UART's receive fifo
is only 2 characters deep. If it's full and 3rd character comes in,
then the UART will detect an "overrun error" and it will lock up.
To clear this situation automatically, you should add the ERRORS
parameter to your #use rs232() statements. (This only works
with a hardware UART). You should add ERRORS to all your
programs.
rnielsen
PostPosted: Mon Mar 26, 2007 1:20 pm     Reply with quote
You are declaring your variables, a & b, inside of your while() loop. Don't do this. Declare them at the top of your main() if you want them to be Local variables or declare them close to the top of the file if you want them to be Global variables.
I would use the #int_RA interrupt to receive the character. I would use the interrupt to catch the character, stuff it in a variable and then check that variable in the main() body. There are multiple examples of RS232 communications throughout the forum.
Ronald
PostPosted: Mon Mar 26, 2007 1:29 pm     Reply with quote
You mean #int_rda.
bestbuylvr
PostPosted: Mon Mar 26, 2007 2:16 pm     Reply with quote
Thank you guys for the help, I got the serial to work using the carriage return and declaring the variables in the right spot (dumb mistake, thank you) and I will try using the interrupt on it shortly. Again, thank you for your help, and hopefully I won't need too much more help with this one.
rnielsen
PostPosted: Mon Mar 26, 2007 4:09 pm     Reply with quote
You mean #int_rda.
Yah, that one. I think the 'd' must have fallen off my keyboard this morning but it's back now. Wink
bestbuylvr
PostPosted: Wed Mar 28, 2007 6:54 am     Reply with quote
OK, so I programmed the interrupt as you sugested and moved the variable declarations. I now have the following programs written trying to talk serially. I am only trying for one way at the moment, and when I send the number 5, I get the response as if I am sending something else (a red LED). When I use the get_int function in the interrupt, I get a green LED, which is what happens when a=5, but I get nothing if the wrong value is detected. I assume the "BYTE a" line gets the incoming number, correct?
Here is code 1 sending the value 5:
#include <18f452.h>
#include <stdlib.h>
#include <INPUT.C>
main(){
int8 a, b;
delay_ms(2000);
while(1){
   a=5;
   printf("%d\n\r", a);
   delay_ms(5);
Here is code 2 recieving the value and using the intterupt:
#include <18f452.h>
#include <stdlib.h>
#include <INPUT.C>
#use rs232(baud=2400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8, ERRORS)
#INT_RDA
   void rda_interrupt () {
      BYTE a;
        // a = get_int();  //WORKS WITH CORRECT VALUE INPUT ONLY
      if (a==5) {
      else if (a!=5) {
      else {
void main () {
int a, b;
   setup_adc(ADC_OFF);
      setup_spi(FALSE);
      setup_wdt(WDT_OFF);
delay_ms(200);
      delay_ms(200);
enable_interrupts(INT_RDA);
while(TRUE){
   printf("%d \n\r", a);
PostPosted: Wed Mar 28, 2007 12:24 pm     Reply with quote
You're sending a linefeed and a carriage return. get_int() calls the
get_string() function. get_string() is looking for a carriage return to
end the line. Change the code to this:
printf("%d\r", a);
bestbuylvr
PostPosted: Thu Mar 29, 2007 7:35 am     Reply with quote
Thank you for clearing that up, the program now works as it was intended. I now am trying to use an RF transmitter over the serial connection between the PIC's and the program is interrupting on the garbage interference and getting stuck. I programmed the kbhit() function into the program, but am still not having any luck. Is there by any chance a function that only reads an int directly before a \r is recieved? If not, do you know any other way to get around this? Thanks you for helping. Here is the code I am using now in the second PIC, the first remains the same:
#include <18f452.h>
#include <stdlib.h>
#include <INPUT.C>
#define  KEYHIT_DELAY   500     // in milliseconds
char timed_get_int() {
   long timeout;
   int retval;
   timeout=0;
   while(!kbhit() && (++timeout< (KEYHIT_DELAY*100)))
      delay_us(10);
   if(kbhit())
      retval = get_int();
      retval = 0;
   return(retval);
#INT_RDA
      BYTE a;
         a = timed_get_int();  //WORKS WITH CORRECT VALUE INPUT ONLY
      if (a==5) {
      else if (a!=5) {
      else {
void main () {
int a, b;
   setup_adc(ADC_OFF);
      setup_spi(FALSE);
      setup_wdt(WDT_OFF);
delay_ms(200);
      delay_ms(200);
while(TRUE){
