Low voltage PIC
PIC learner
Low voltage PIC
PostPosted: Mon Mar 26, 2007 1:37 am     Reply with quote
Hi people,
I am using pIC16F916 coz i have to make a product which runs on 3V. i have a problem . it is interfaced to the lcd.. can lcd's operate with 3 volts..
and another doubt, in PIC printf statements.. what does 3.2%, 4.2 % signify
PostPosted: Mon Mar 26, 2007 3:02 am     Reply with quote
There are many PIC processors that can run at 3V, the PIC16F916 is not the only one. Note that at 3V the maximum frequency for this chip model is 10MHz.
Some can, others can't. Please provide more details about the LCD: type number, manufacturer, etc.
These are standard formatting parameters for the printf statement. For a detailed explanation check any C book describing the printf statement.
rnielsen
PostPosted: Mon Mar 26, 2007 8:30 am     Reply with quote
The LCD should be able to interface with a 3.3V controller. The minimum level that is, usually, required to be considered a '1' is 2.4V. When the output, of a 3.3V part, swings high it should go above this level. The only problem is that most LCD's require 5V for their onboard IC's. There should be 3.3V LCD's around but I, personally, haven't looked for any before.
Ronald
PIC Learner
PostPosted: Wed Mar 28, 2007 3:08 am     Reply with quote
THank u very much for the reply.. i am using a 16 x 2 LCD. it works with 5V... should check out for other LCD's... hey, thank u for pointing out tat PCI16F916 works with 10F
