OT:1-wire iButton protection
cstan_02
PostPosted: Sun Mar 25, 2007 9:06 pm     Reply with quote
I have done this i-button reader of which the MCU is PIC16LF73 working with 3V. Now that's not at all the problem. The 1-wire data line is connected to the PIC pin directly with just a few ohms of resistance and a zener diode in parallel. The idea is to protect the PIC pin in case somebody tries to sabotage the system by applying high voltages on the 1-wire dataline in which case the PIC pin will be rendered useless. I'm afraid that my setup might not be fully protected. I've seen other circuits which use a schottky diode just in series with the dataline with the anode towards the PIC. And another I/o pin connected to the data line. Like this..
[INT0]
PIN_B0 Schottky 10-30 Ohm
[]PIC------------------|>|-------------/\/\/\/------------------|Reader data line
| |-----|<|---------------GND
PIN_B4----------| Zener Diode
This is the circuit that i'm talking about. How can i make it work through the firmware ? I'm using the CCS library for the touch device. Hope you guys can give me some hints. Thanks.
cstan_02
Oops!
PostPosted: Sun Mar 25, 2007 10:03 pm     Reply with quote
The picture that i draw does not appear exactly as i thought it would. Too bad that we can't upload pictures drectly. Sad
PostPosted: Sun Mar 25, 2007 10:30 pm     Reply with quote
1. Edit your original post.
2. Put the ASCII art inside a "code block". This will preserve the
formatting. One problem is that the font used to enter the post is
not the same as the one used to display it. So you need to:
3. Preview your edited post. If it doesn't look correct, edit it slightly
and preview it again. Repeat this until you get it right. Then post it.
cstan_02
Any way to do this?
PostPosted: Mon Mar 26, 2007 1:15 am     Reply with quote
                           Schottky           33 Ohm
PIN_B0-------------------------|>|-------------/\/\/\/----------------|Reader data line
            5K6          |             |-----|<|---------------GND
PIN_B4--/\/\/\/----------|                Zener Diode
The schottky is for added protection in case of sabotage by applying high voltage, but the the 1-wire does not work with the diode on the line. The pin_b4 is used to overcome the problem. I'm just wondering how. Thanks.
