question regarding fuses
mcnscott2
PostPosted: Sun Mar 25, 2007 10:30 pm     Reply with quote
I'm using this *code to implement a project, however this is my first in C and not assembly, In assembly a directive for the programmer (PICSTART Plus) has to be included, but this code doesn't have one
#include <SLED4C_1620a.h>          // header file & function prototypes
void Main(void)
   int announce=0;                 // holds # of time/temp announcements
   init();                         // initialize I/O & peripherals
   while(1)                        // loop forever
     read_time();                  // read & display DS1307 time
     read_temp();                  // read & display DS1620 temp
     // announce time/temp on roll-over from 59 to 00 minutes
     if(ds1307_regs[MINUTES_REG]==0x00)
       if(!announce)               // say time & temp only if announce=0
         say_time();               // say the current time
         delay_ms(3000);           // delay 3 seconds
         say_temp();               // say the current temperature
         announce +=1;             // increment announcement counts
     if(!ds1307_regs[MINUTES_REG]==0x00)
        announce=0;                // clear announcements until it's time
and the header file
File name: SLED4C_1620a.h
Header file for SLED4C_1620a.c
#include <16f876A.h>
#use rs232(baud=2400, xmit=PIN_C0)
#use i2c(Master, SDA=PIN_B0, SCL=PIN_B1)
I've always used MPLAB and am integrating C with it now, so does the IDE automatically set the fuses? Looking at the CCS configuration window inside MPLAB, it seems it does, I'm not sure. Do I have to even put the fuses in or has my assembly learning been all wrong? Thank you.
*note code is from www.rentron.com
PostPosted: Sun Mar 25, 2007 11:09 pm     Reply with quote
No, it doesn't automatically do it. You need to add a #fuses statement,
as shown in bold below.
#include <16F876A.h>
#fuses HS, NOWDT, BROWNOUT, PUT, NOLVP
Also, your #use rs232() statement will create a software UART.
If you want a hardware UART (much better), than use this line instead:
mcnscott2
PostPosted: Mon Mar 26, 2007 1:31 am     Reply with quote
Great, thank you! I'll implement the changes tomorrow.
