problem with printf using PIC16F687 - garbage on RS232
Goto page 1, 2  Next
hanhao
PostPosted: Sun Mar 25, 2007 7:04 pm     Reply with quote
here is my header
#FUSES RC                       //Resistor/Capacitor Osc with CLKOUT
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOPUT                    //No Power Up Timer
//#use delay(internal=8M)
#use delay(clock=2000000)
#use rs232(baud=19200,parity=N,xmit=PIN_B7,rcv=PIN_B5,bits=8)
here is my printf command
printf("TESTING");
here is the settings i put on serial input/output monitor. This program comes as a tool on CCS C compiler
here is the garbage i got
note that the first few lines are different because the bytes are not inverted
i set inversion because i dont have a NOT gate or a MAX chip
the serial was connected to pin 10 port B7
can anyone tell me why i am getting garbage instead of "TESTING"?
and the solution to this problem
Mattr0
PostPosted: Sun Mar 25, 2007 7:16 pm     Reply with quote
Chances are you oscillator setting are incorrect. In fact in your header file you have selected RC with 20 mhz it should be HS
try
#FUSES HS                     // High speed oscillator
HS must be used when the speed is great or than 4 Mhz.
[/quote]
hanhao
PostPosted: Sun Mar 25, 2007 7:46 pm     Reply with quote
thanks for your help
but it didnt work
again, the earlier part is for non inverted bytes and the 2nd portion is inverted
here is the result, seems to be the same...
i also changed the rate to 9600 and these are my results
PostPosted: Sun Mar 25, 2007 8:08 pm     Reply with quote
What crystal, oscillator, resonator, or R-C circuit do you have connected
to the CLKIN and CLKOUT pins on the 16F687 ?
If you have a crystal, tell the value of the capacitors that you have
connected to it.
A crystal looks like this:
http://rocky.digikey.com/WebLib/ECS/Web%20Photos/HC-49US.jpg
An oscillator looks like this:
http://rocky.digikey.com/WebLib/CTS/Web%20photos/MXO45.jpg
hanhao
PostPosted: Sun Mar 25, 2007 8:12 pm     Reply with quote
currently no crystal connected to OSC1 and OSC2
they are floating pins
btw i am using CCSC compiler 4.013 and MPLAB IDE 7.5
PostPosted: Sun Mar 25, 2007 8:23 pm     Reply with quote
Try this test program. Type characters into the terminal window.
See if the PIC sends them back to the PC. It should work.
This program uses the PIC's internal RC oscillator.
#include <16F687.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, PUT, BROWNOUT
#use delay(clock=8000000)
#use rs232(baud=9600, xmit=PIN_B7, rcv=PIN_B5, ERRORS)
int8 c;
   c = getc();
   putc(c);
Humberto
PostPosted: Sun Mar 25, 2007 8:29 pm     Reply with quote
Using INTRC_IO oscillator type, does it need to configure the oscillator frequency using
setup_oscillator(OSC_8MHZ) ?
If it doesn´t defined, what´s the default osc freq ?
Humberto
PostPosted: Sun Mar 25, 2007 8:37 pm     Reply with quote
If the #use delay() statement is placed below the #fuses statement,
the compiler will automatically setup the internal oscillator correctly.
hanhao
PostPosted: Sun Mar 25, 2007 8:51 pm     Reply with quote
#include <16F687.h>
int8 c;
   c = getc();
   putc(c);
here are the results when i type "qwerty" on my keyboard
inverted bytes, note that i typed "qwerty qwerty"
non inverted bytes, note that i type "qwertyuopasdfghjklzxcvbnm" in this case and hence the longer line
non inverted bytes actually makes more sense but still does not display the exact stuff i type
Humberto
PostPosted: Sun Mar 25, 2007 8:59 pm     Reply with quote
hanhao,
Have you changed the baud rate from 19200 to 9600 in the serial monitor to match
the example code posted by PCM Programmer?
If it doesn´t fix, pls tell us your hardware arrangement.
Humberto
hanhao
PostPosted: Sun Mar 25, 2007 9:07 pm     Reply with quote
Humberto wrote:
hanhao,
Humberto
yes i did
here the configuration
i have an O scope with me, want me to probe anything? Laughing
Humberto
PostPosted: Sun Mar 25, 2007 9:26 pm     Reply with quote
According to your drawing, it seems like you are connecting the PIC pins directly to
the DB9 connector, hence directly to RS232 levels, wich is wrong. PIC voltages
swing between 0 to 5VDC, RS232 levels swing between +12 to -12VDC.
You need to connect a level converter like MAX232 in between them.
http://www.ccsinfo.com/faq.php?page=pic_to_pc
http://www.ccsinfo.com/faq.php?page=rs232_errors
Humberto
hanhao
PostPosted: Sun Mar 25, 2007 9:48 pm     Reply with quote
i do not have a MAX232 chip
but i do have 2N7002k chips
can i use this configuration instead?
http://www.botkin.org/dale/rs232_interface.htm
hanhao
PostPosted: Sun Mar 25, 2007 10:52 pm     Reply with quote
i guess i need this connection
from http://www.lookrs232.com/rs232/level_converters.htm
OR THIS
from http://sodoityourself.com/max232-serial-level-converter/
will try out once the chip comes
i notice that the 2 schematics have different capacitor values
which value should i use? 10u or 1u?
hanhao
PostPosted: Mon Mar 26, 2007 12:54 am     Reply with quote
opps, i cant find a MAX232 chip, but i do have a surface mount sipex SP3243 chip. i guess i'll use that in place of the MAX232
Goto page 1, 2  Next
Page 1 of 2
