hadeelqasaimeh
ext_int |
Posted: Sun Mar 25, 2007 3:03 pm |
hi
this code dont sense external intterput..but whats wrong with it??
#include <16f877a.h>
#include "lcd_kbd1.c"
#include <string.h>
#fuses xt,NOWDT,NOLVP
#byte tris_d =0x00
//#priority rda,ext //serial is higher proirety
#define address 10 // Location in EEPROM
float value = 0;
int1 flag;
#INT_EXT
void external_isr() {
// value = read_eeprom (address);
value= value+0.1003;
// write_eeprom (address, value);
//flag=1;
flag=0;
output_low(PIN_D0);
// enable_interrupts(INT_RDA);
enable_interrupts(INT_EXT);
ext_int_edge(H_TO_L);
LCD_Init ( );
LCD_PutCmd ( CLEAR_DISP );
//main:
LCD_SetPosition (LINE_16_1);//80-8f
printf(LCD_PutChar,"value:");
LCD_SetPosition (LINE_16_2);//80-8f
printf(LCD_PutChar,"\f%6.3f",value);
delay_ms(200);
// value= value+0.0003;
// if (flag==1) {
// value= value+0.1003;
// output_high(PIN_D7);
// delay_ms(500);
// flag=0;
}//while
}//MAIN
thank you |
Posted: Mon Mar 26, 2007 4:33 am |
You can't read/write a floating point number to/from the EEPROM like this. You need to perform four transfers to move the individual bytes, seperating them, and then putting them together again, using 'make8/make32', or a union. Do a search on here for dozens of examples of how to do this.
Almost certainly, the interrupt is occurring, and just not giving the data change you expect.
Seperately, _do not_ change the active interrupt edge, after enabling the interrupt. This can give a spurious interrupt. Change the edge, clear the interrupt, then enable it.
Consider _not_ using floating point arithmetic inside the interrupt hadler, and also, not writing to the eeprom in here. Both are _slow_, and having the routines both inside and outside the interrupt, means that the interrupt will be disabled for long periods in the main.
hadeelqasaimeh
Posted: Mon Mar 26, 2007 6:03 am |
yes you are right,,,i change it onto read and write flaot value like in the faq
its ok!!
but still lcd proplem |
hadeelqasaimeh
Posted: Tue Mar 27, 2007 6:06 am |
i think lcd driver use port b..so it cause problem
thank you |
