use i2c question!
Goto page Previous  1, 2
domdom
PostPosted: Sat Mar 24, 2007 11:43 pm     Reply with quote
Hi PCM programmer,
Did you see the url? what is my problem for my window terminal?
Or may be the code is not working?
PostPosted: Sat Mar 24, 2007 11:59 pm     Reply with quote
You have a problem with sending serial data to Hyperterminal.
Even if the i2c code produces bad output, you should still see
the text in this printf statement:
printf("read %c \n\r", data);
You should see the word "read" in the Hyperterminal window.
I don't see it.
Try this very simple program, just to test if you can talk to PIC
by typing characters into the HyperTerminal window:
http://www.ccsinfo.com/forum/viewtopic.php?t=29538&start=6
Modify the PIC #include file and #use delay() statement
as required to fit your actual hardware.
You shoul be able to type characters and have the PIC send
them back to HyperTerminal, where they are displayed.
funmix
PostPosted: Sat Mar 31, 2007 11:06 am     Reply with quote
Hi PCM programmer,
the example you use for master i2c is 16f877a, i changed the 16877A to 18f4520. It doesn't work.
Is there any errata for this chip?
PostPosted: Sat Mar 31, 2007 12:24 pm     Reply with quote
There are many i2c erratas on the A1 silicon of the 18F4520.
http://ww1.microchip.com/downloads/en/DeviceDoc/80209f.pdf
This page says there are three revisions: A1, B2, and B3.
http://www.microchip.com/stellent/idcplgidcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010297
To find the silicon revision of your PIC, connect it to an ICD2 and
then select "Connect" from the Programmer menu in MPLAB.
It will display the revision. That's for Microchip tools. The CCS
tools probably also do it.
Page 2 of 2
