Timer experts, HELP!
Felipe
PostPosted: Thu Mar 22, 2007 7:20 pm     Reply with quote
If you understand my question and if you know the answer, please tell me!
I wanna know what is the clock input of the timers below. Is it the primary clock(div by 4, of course) or the internal clobk(also div by 4)?
timer0
timer1
timer2
timer3
thanks
mskala
PostPosted: Thu Mar 22, 2007 8:36 pm     Reply with quote
You have to look at the diagrams in the PIC datasheet for part you're using. In looking at 1 that I use, 18F4520, it shows that all peripherals, which would include the timers, are driven from the same clock as CPU. That can be from all the usual oscillator and PLL modes.
But also, looking at block diagram of each timer module, they can accept 'Fosc/4' CPU clock or various other clocking options.
Humberto
PostPosted: Thu Mar 22, 2007 9:38 pm     Reply with quote
You should read the linked thread posted by newguy wich is very informative,
you will know how to use the setup options of the internal timers modules.
http://www.ccsinfo.com/forum/viewtopic.php?t=22467
Humberto
