Alan Guest
Another question regarding rs232 |
Posted: Thu Nov 23, 2006 5:11 am |
Good day,
I need to use an rs232 at baud rates higher than 115200. As far as i see, the compiler doesn't allow me to exceed 115200, while, for what i know, writing in assembler, could have made it possible. Does anyone know a way to overcome this problem still using the ccs compiler?
Thank you in advance,
Alan |
asmallri
Posted: Thu Nov 23, 2006 5:19 am |
If the restriction is real then it is still easy to do.
#define XTAL_FREQ 40000000
#define BaudRate 115200
#define BRG_divisor XTAL_FREQ/(16*BaudRate)
// define register location for this PIC
#define SPBRG 0x0FAF
// cheat and use #use rs232 to set up everything for you at 115200
#use rs232 ......
// now set the divisor you really need
SPBRG = BRG_divisor;
_________________ Regards, Andrew
Posted: Thu Nov 23, 2006 6:17 am |
It depend on your master crystal rate.
The following:
#use delay(clock=40000000)
#use rs232(baud=250000, xmit=PIN_C6, rcv=PIN_C7)
Happily compiles (since 250K, is nice and easy to do from a 40Hz crystal). However:
#use delay(clock=10000000)
#use rs232(baud=460800, xmit=PIN_C6, rcv=PIN_C7)
Will error on the baud rate, since the possible nearest dividers (/5, and /6), will give about 8% error in the rate (the compiler will not allow errors about about 3%). However changing to a slightly slower clock, that is a nicer multiple:
#use delay(clock=9216000)
Will happily work again.
There is no limit at 115200, in the compiler. The limit is based on whether the rate you are selecting will work with the crystal you are using. I have used 921600bps, with a 9.216MHz crystal, and the *4 PLL (36.864MHz).
There is separately, a limit in the code, when using 'software' RS232, since this requires several instructions per loop, and again the compiler will error on the baud rate, if there is not enough time for the code needed.
Alan Guest
rs232 |
Posted: Thu Nov 23, 2006 6:41 am |
Thank you both very much. I'll try and let you know.
Alan |
Sigma
Posted: Wed Mar 21, 2007 7:29 pm |
Hi, Ttelmah,
If I am using a 4Mhz crystal and 16F76 device, the following statement is allowed by the compiler.
#use delay(clock=3790000)
#use rs232(baud=115200, parity=N, BITS=8, xmit=TXD, rcv=RXD) //Hardware UART
What will be the consequences as a result of inconsistency of frequency?
regards
Sigma |
Posted: Thu Mar 22, 2007 4:11 am |
It won't work.
The compiler will solve the divider as:
(3790000/115200)/4 = 8.22
Hence it'll select /8 as the divider (7 into the setup register).
With your real crystal, this will give:
4000000/(4*8) = 125000bps.
Error = 125000/115200 = 1.0857*.
8.57%
Now, the error that can exist without problems, depends on the sampling algorithm of the receive UART, the word length etc. etc., but in general, 3 to 4% is a 'good guide', with 5.5% being the absolute upper limit for most systems. This works out, because the simpler chips generally sample in the middle of the bit time. For a 10 bit transmission (1 start bit, 8 bit data, and one stop bit), with sampling only occurring on the data bits, if the system starts counting from the leading edge of the start bit, it'll go outside the data bits, if the total timing error exceeds this.
The CCS default, is not silly. It tells you if your hardware _can_ handle the speeds required, and though in a few small circumstances, 'tricking' it, may be worthwhile, in general, if the compiler says the rate won't work, it won't...
Sigma
Posted: Thu Mar 22, 2007 7:47 pm |
Thanks. Ttelmah.
That means if the baud rate is fixed, lets say, 115200bps. We had to choose the correct crystal?
regards
Sigma |
Posted: Fri Mar 23, 2007 3:36 am |
Sigma wrote: | Thanks. Ttelmah.
regards
Sigma |
Exactly.
You want a crystal, that is an integer multiple of the required rate*4.
So for 115200bps, and a crystal 'near' 4MHz, you want:
115200*4 = 460800
integer multiples are:
*8 = 3686400Hz
*9 = 4147200Hz
Either of these crystals wll work fine. The former is a standard crystal, for exactly this reason (it also works nicely for all the other standard baud rates).
