ahmedzamus
Array element increment? |
Posted: Thu Mar 22, 2007 6:05 am |
int8 mydata[4];
when I use command mydata[2]++; I got all mydata elemnts incremented not only mydata[2];
What is problem in My code?
My version is 3.236.
Thanks |
Posted: Thu Mar 22, 2007 4:26 pm |
Here is a test program that I compiled with PCM vs. 3.236.
You didn't say what PIC you're using, so I compiled it for a 16F877.
#include <16F877.H>
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
int8 mydata[4];
mydata[2]++;
Here's the .LST file:
0004: CLRF 04
0005: MOVLW 1F
0006: ANDWF 03,F
0007: BSF 03.5
0008: BSF 1F.0
0009: BSF 1F.1
000A: BSF 1F.2
000B: BCF 1F.3
.................... int8 mydata[4];
.................... mydata[2]++;
000C: BCF 03.5
000D: INCF 23,F
.................... while(1);
000E: GOTO 00E
Here is the mydata array in the .SYM file:
Code: | 021-024 main.mydata |
Data is stored LSB first by the compiler. So the .LST file shows
that it's incrementing the byte at index = 2, which is correct.
It's not incrementing all bytes in the array. |
ahmedzamus
still problem to increment one element |
Posted: Thu Mar 22, 2007 5:20 pm |
My processor is 18F458
Here is My code :
if(button(PIN_c7, 0, 50, 10, c7, 1))
x++;
output_toggle(PIN_b6);
output_toggle(PIN_d0);
output_toggle(PIN_d1);
mydata[0]++;
OUTPUT_B(mydata[1]);
each time I increment mydata[0] the mydata[1] is incremented also!
please elet me know what is problem?
here is list :
................... x++;
03F4: INCF 1E,F
.................... output_toggle(PIN_b6);
03F6: BCF F93.6
03F8: BTG F8A.6
.................... output_toggle(PIN_d0);
03FA: BCF F95.0
03FC: BTG F8C.0
.................... output_toggle(PIN_d1);
03FE: BCF F95.1
0400: BTG F8C.1
.................... mydata[0]++;
0402: INCF 20,F
.................... //*(mydata+0)=*(mydata+0)+1;
.................... //mydata[1]=0;
.................... OUTPUT_B(mydata[1]);
0404: CLRF F93
0406: MOVFF 21,F8A
Posted: Thu Mar 22, 2007 5:34 pm |
I don't see it in the .LST file. The ASM code only increments
the first byte in the array. Maybe some other code in your
program is incrementing the 2nd byte in the array. |
ahmedzamus
Posted: Thu Mar 22, 2007 5:43 pm |
all items is incremented,not only [1].
Here is My full program code :
int8 mydata[6] ;
setup_adc_ports(AN0_VREF_VREF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_ON);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
setup_timer_2(T2_DIV_BY_16,8,8);
setup_timer_3(T3_INTERNAL|T3_DIV_BY_8);
lcd_init();
disable_interrupts(INT_TIMER0);
disable_interrupts(INT_TIMER1);
disable_interrupts(INT_TIMER2);
disable_interrupts(INT_TIMER3);
disable_interrupts(GLOBAL);
setup_oscillator(False);
output_low(PIN_b6);
output_low(PIN_c0);
output_low(PIN_c1);
output_low(PIN_c2);
output_HIGH(PIN_c3);
set_tris_c(0xf0);
set_tris_d(0xfd);
while (1)
if(button(PIN_c4, 0, 50, 10, c4, 1))
y++;
x++;
mydata[0]++;
//write_expanded_outputs(mydata);
delay_ms(10);
My list :
0202: CLRF FF8
0204: BCF FD0.7
0206: BSF 0D.7
0208: CLRF FEA
020A: CLRF FE9
020C: BSF FC1.0
020E: BSF FC1.1
0210: BSF FC1.2
0212: BCF FC1.3
0214: MOVLW 07
0216: MOVWF FB4
0218: CLRF 19
021A: CLRF 1A
021C: CLRF 1B
021E: CLRF 1C
0220: CLRF 1D
0222: CLRF 1E
0224: CLRF 1F
.................... int8 mydata[6] ;
.................... setup_adc_ports(AN0_VREF_VREF);
0226: BSF FC1.0
0228: BSF FC1.1
022A: BSF FC1.2
022C: BSF FC1.3
.................... setup_adc(ADC_CLOCK_INTERNAL);
022E: BCF FC1.6
0230: BSF FC2.6
0232: BSF FC2.7
0234: BSF FC1.7
0236: BSF FC2.0
.................... setup_psp(PSP_DISABLED);
0238: BCF F96.4
.................... setup_spi(FALSE);
023A: BCF FC6.5
023C: BCF F94.5
023E: BSF F94.4
0240: BCF F94.3
0242: MOVLW 00
0244: MOVWF FC6
0246: MOVWF FC7
.................... setup_wdt(WDT_ON);
0248: BSF FD1.0
.................... setup_timer_0(RTCC_INTERNAL);
024A: MOVLW 80
024C: MOVWF FD5
.................... setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
024E: MOVLW 85
0250: MOVWF FCD
.................... setup_timer_2(T2_DIV_BY_16,8,8);
0252: MOVLW 38
0254: IORLW 06
0256: MOVWF FCA
0258: MOVLW 08
025A: MOVWF FCB
.................... setup_timer_3(T3_INTERNAL|T3_DIV_BY_8);
025C: MOVF FB1,W
025E: ANDLW 48
0260: IORLW B5
0262: MOVWF FB1
.................... lcd_init();
0264: BRA 01AE
.................... disable_interrupts(INT_TIMER0);
0266: BCF FF2.5
.................... disable_interrupts(INT_TIMER1);
0268: BCF F9D.0
.................... disable_interrupts(INT_TIMER2);
026A: BCF F9D.1
.................... disable_interrupts(INT_TIMER3);
026C: BCF FA0.1
.................... disable_interrupts(GLOBAL);
026E: BCF FF2.6
0270: BCF FF2.7
0272: BTFSC FF2.7
0274: BRA 0270
.................... setup_oscillator(False);
0276: CLRF FD3
.................... output_low(PIN_b6);
0278: BCF F93.6
027A: BCF F8A.6
.................... output_low(PIN_c0);
027C: BCF F94.0
027E: BCF F8B.0
.................... output_low(PIN_c1);
0280: BCF F94.1
0282: BCF F8B.1
.................... output_low(PIN_c2);
0284: BCF F94.2
0286: BCF F8B.2
.................... output_HIGH(PIN_c3);
0288: BCF F94.3
028A: BSF F8B.3
.................... set_tris_c(0xf0);
028C: MOVLW F0
028E: MOVWF F94
.................... set_tris_d(0xfd);
0290: MOVLW FD
0292: MOVWF F95
.................... while (1)
.................... if(button(PIN_c4, 0, 50, 10, c4, 1))
0294: MOVLW 7C
0296: MOVWF 27
0298: MOVLW 14
029A: MOVWF 26
029C: CLRF 28
029E: MOVLW 32
02A0: MOVWF 29
02A2: MOVLW 0A
02A4: MOVWF 2A
02A6: MOVLW 01
02A8: MOVWF 2B
033E: MOVF 01,F
0340: BZ 0344
.................... y++;
0342: INCF 1F,F
.................... if(button(PIN_c7, 0, 50, 10, c7, 1))
0344: MOVLW 7C
0346: MOVWF 27
0348: MOVLW 17
034A: MOVWF 26
034C: CLRF 28
034E: MOVLW 32
0350: MOVWF 29
0352: MOVLW 0A
0354: MOVWF 2A
0356: MOVLW 01
0358: MOVWF 2B
03EE: MOVF 01,F
03F0: BZ 040E
.................... x++;
03F2: INCF 1E,F
03F4: BCF F93.6
03F6: BTG F8A.6
03F8: BCF F95.0
03FA: BTG F8C.0
03FC: BCF F95.1
03FE: BTG F8C.1
0400: INCF 20,F
0402: CLRF F93
0404: MOVFF 21,F8A
.................... //write_expanded_outputs(mydata);
.................... delay_ms(10);
0408: MOVLW 0A
040A: MOVWF 27
040C: RCALL 00FA
040E: BRA 0294
Posted: Thu Mar 22, 2007 6:15 pm |
I think you should put in some printf statements to display the
value of the array before and after you increment byte 0 in it.
Example:
printf("Before: %x %x %x %x \n\r",
mydata[0], mydata[1], mydata[2], mydata[3]);
mydata[0]++;
printf("After: %x %x %x %x \n\r",
This will tell you if the increment statement is affecting
all the other bytes in the array. |
