Can it work ?
soulweed
Can it work ?
PostPosted: Thu Mar 22, 2007 9:01 am     Reply with quote
I need to use 2 Rx and 1 Tx then i use 74HCT157 for select data source
Please tell me.Can it work?
I 'm using PIC18F452
SherpaDoug
PostPosted: Thu Mar 22, 2007 10:32 am     Reply with quote
Sure, put the multiplexer chip between the PIC and the RS232 level shifter.
Humberto
PostPosted: Thu Mar 22, 2007 11:53 am     Reply with quote
Also you can add "extra Rx hardware" functionalities using the INT0..INT2 (pins RB0...RB2)
with the advantage that it will get an interrupt (EXT_INT) in the Start bit of the first
arrived character and do not need any polling nor multiplexing overhead
generated by handling the 74HCT157.
Humberto
kender
Re: Can it work ?
PostPosted: Thu Mar 22, 2007 3:31 pm     Reply with quote
Yes, it can. But keep in mind that you will get the RX interrupt only from the RX line that's commutated to the PIC.
