Pei-Yu Huang Guest
| HW i2c doesn't work when using 2 16f877. (1 as master, 1 as |
Posted: Thu Dec 06, 2001 11:08 pm |
I have writen this code to do a master slave i2c comunication between two PIC16F877.
******* Master **********
#include <16F877.H> // device header file from CCS-C
#fuses HS, NOWDT, NOBROWNOUT, NOPROTECT
#use delay(clock=20000000) // 20 MHz crystal oscillator
#use I2C(master, sda=PIN_C4, scl=PIN_C3, SLOW, NOFORCE_SW)
// ----- function prototyping ----------------------
void i2c_master();
void init_i2c();
// ----- function prototyping ----- finished ---------
void i2c_master(){
i2c_start();
i2c_write(0xa0);
i2c_write(0x45);
i2c_write(0x67);
i2c_stop();
delay_ms(20);
void init_i2c(){
output_float(PIN_C3);
output_float(PIN_C4);
#org 0x0800 // fixed address for main(), written in YZ_ICP
main() {
init_i2c();
enable_interrupts(INT_SSP);
while (TRUE) {
i2c_master();
output_low(PIN_A5);
output_high(PIN_A5);
************* Slave **************
#use I2C(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xa0, SLOW, NOFORCE_SW)
byte address, data0, data1;
#INT_SSP
void i2c_slave()
if(i2c_poll()==TRUE){
address=i2c_read();
data0=i2c_read();
data1=i2c_read();
main() {
while (TRUE) {
output_low(PIN_A5);
delay_ms(125);
delay_ms(125);
************ end of code **************
Here are some problems:
1. The master blocked when executing line i2c_write(0xa0); .
Therefore, slave didn't get anything from master.
2. So, I tried using software i2c with master instead of using hardware with master. (Slave didn't change.) Here is the code for master by using software i2c. (RC6 as SCL, RC7 as SDA)
*********** Master ***********
#use I2C(master, sda=PIN_B7, scl=PIN_B6)
// ----- function prototyping ------------------------------
void i2c_master();
void init_i2c();
// ----- function prototyping ----- finished -------------
void i2c_master(){
i2c_start();
i2c_write(0xa0);
i2c_write(0x45);
i2c_write(0x67);
i2c_stop();
delay_ms(20);
void init_i2c(){
output_float(PIN_B6);
output_float(PIN_B7);
main() {
init_i2c();
port_b_pullups(TRUE);
while (TRUE) {
i2c_master();
output_low(PIN_A5);
Then the slave could get something from master. But all he got was 0xA0. It's seems that he missed 0x45 and 0x67.
I am sure the i/o conncetion is ok. And the pullup resister was added. Would you please help me find out what's wrong with my code? Sorry for taking your time.
IDE Version: 3.2
PCB Version: 3.002
PCM Version: 3.025
Thank you for the support. Best regards.
Pei Yu Huang
PS: Sorry for my poor English.
___________________________
Original Post ID: 1496 |
Renato and Davide Guest
| Re: HW i2c doesn't work when using 2 16f877. (1 as master, 1 |
Posted: Fri Dec 07, 2001 3:55 am |
:=Hello,
:=I have writen this code to do a master slave i2c comunication between two PIC16F877.
:=******* Master **********
:=#include <16F877.H> // device header file from CCS-C
:=#fuses HS, NOWDT, NOBROWNOUT, NOPROTECT
:=#use delay(clock=20000000) // 20 MHz crystal oscillator
:=#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
:=#use I2C(master, sda=PIN_C4, scl=PIN_C3, SLOW, NOFORCE_SW)
:=// ----- function prototyping ----------------------
:=void i2c_master();
:=void init_i2c();
:=// ----- function prototyping ----- finished ---------
:=void i2c_master(){
:=i2c_start();
:=i2c_write(0xa0);
:=i2c_write(0x45);
:=i2c_write(0x67);
:=i2c_stop();
:=delay_ms(20);
:=void init_i2c(){
:=output_float(PIN_C3);
:=output_float(PIN_C4);
:=#org 0x0800 // fixed address for main(), written in YZ_ICP
:=main() {
:=init_i2c();
:=enable_interrupts(GLOBAL);
:=enable_interrupts(INT_SSP);
:=while (TRUE) {
:=i2c_master();
:=output_low(PIN_A5);
:=delay_ms(500);
:=output_high(PIN_A5);
:=delay_ms(500);
:=************* Slave **************
:=#use I2C(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xa0, SLOW, NOFORCE_SW)
:=byte address, data0, data1;
:=#INT_SSP
:=void i2c_slave()
:=if(i2c_poll()==TRUE){
:=address=i2c_read();
:=data0=i2c_read();
:=data1=i2c_read();
:=main() {
:=while (TRUE) {
:=delay_ms(125);
:=delay_ms(125);
:=************ end of code **************
:=Here are some problems:
:=1. The master blocked when executing line i2c_write(0xa0); .
:=Therefore, slave didn't get anything from master.
:=2. So, I tried using software i2c with master instead of using hardware with master. (Slave didn't change.) Here is the code for master by using software i2c. (RC6 as SCL, RC7 as SDA)
:=*********** Master ***********
:=#use I2C(master, sda=PIN_B7, scl=PIN_B6)
:=// ----- function prototyping ------------------------------
:=void init_i2c();
:=// ----- function prototyping ----- finished -------------
:=i2c_start();
:=i2c_write(0xa0);
:=i2c_write(0x45);
:=i2c_write(0x67);
:=i2c_stop();
:=delay_ms(20);
:=void init_i2c(){
:=output_float(PIN_B6);
:=output_float(PIN_B7);
:=main() {
:=init_i2c();
:=port_b_pullups(TRUE);
:=while (TRUE) {
:=i2c_master();
:=delay_ms(500);
:=delay_ms(500);
:=******* end of code ********
:=Then the slave could get something from master. But all he got was 0xA0. It's seems that he missed 0x45 and 0x67.
:=I am sure the i/o conncetion is ok. And the pullup resister was added. Would you please help me find out what's wrong with my code? Sorry for taking your time.
:=IDE Version: 3.2
:=PCB Version: 3.002
:=PCM Version: 3.025
:=Thank you for the support. Best regards.
:=Pei Yu Huang
:=PS: Sorry for my poor English.
I have had the same problem. I had used the wizard. The wizard had put the instruction: setup_spi (FALSE); in the main function of the master and slave. I've Removed the instruction (cancelled!!!) it works!!!.
I hope that this help you.
Original Post ID: 1497 |
Pei-Yu Huang Guest
Posted: Sun Dec 09, 2001 8:07 pm |
:=I have had the same problem. I had used the wizard. The wizard had put the instruction: setup_spi (FALSE); in the main function of the master and slave. I've Removed the instruction (cancelled!!!) it works!!!.
:=I hope that this help you.
Thank you for the suggestion. But I didn't use the setup_spi(FALSE) either in master code or slave code. Do you have any other idea what make the comunication fail? You are so kind. I'd appreciate.
Original Post ID: 1535 |
Davide Guest
Posted: Mon Dec 10, 2001 2:33 am |
:=Thank you for the suggestion. But I didn't use the setup_spi(FALSE) either in master code or slave code. Do you have any other idea what make the comunication fail? You are so kind. I'd appreciate.
Hi, I have noticed that you have mistaken to write the code of the slave.
just this is wrong:
#INT_SSP
void i2c_slave()
address=i2c_read();
data0=i2c_read();
data1=i2c_read();
Because when happens an interrupt it makes the first instruction only: address=i2c_read().
The first time it is correct (is really the address of slave), but the second time it is already mistaken (the second byte incoming is a data byte, not the slave address), the same thing for the third data, it is a data not the address of the slave.
One possible solution is:
byte i=0; //byte == int
#INT_SSP
void i2c_slave()
if (i==0) address=i2c_read();
if (i==1) data0=i2c_read();
else if (i==2) data1=i2c_read();
i++;
Is important assign the incoming data at the right variable.
Another example is EX_SLAVE.c in the EXAMPLE directory in the pic C compiler.
Hello and good job
Original Post ID: 1536 |
Pei-Yu Huang Guest
Posted: Tue Dec 18, 2001 12:25 pm |
:=Hi, I have noticed that you have mistaken to write the code of the slave.
:=just this is wrong:
:=#INT_SSP
:=void i2c_slave()
:=data0=i2c_read();
:=data1=i2c_read();
:=Because when happens an interrupt it makes the first instruction only: address=i2c_read().
:=The first time it is correct (is really the address of slave), but the second time it is already mistaken (the second byte incoming is a data byte, not the slave address), the same thing for the third data, it is a data not the address of the slave.
:=One possible solution is:
:=byte i=0; //byte == int
:=#INT_SSP
:=void i2c_slave()
:= if(i2c_poll()==TRUE)
:= if (i==0) address=i2c_read();
:= else
:= if (i==1) data0=i2c_read();
:= else if (i==2) data1=i2c_read();
:= i++;
:=Is important assign the incoming data at the right variable.
:=Another example is EX_SLAVE.c in the EXAMPLE directory in the pic C compiler.
:=Hello and good job
Thank you for the answer. Software master and hardware slave are now talking to each other very well. You are a very good teacher. :P
Original Post ID: 1691 |
