Interfacing an LCD screen (JE-AN 1286404)
ME109e
PostPosted: Sat Mar 17, 2007 11:01 am     Reply with quote
Hi guys,
I'm using or trying to use a pic 18f4520 with a LCD screen: JE-AN 1286404.
Does anyone know how to wire LCD modules up? I haven't used one before so I don't want to make a mistake an blow the unit up!
I know where the data pins go and the cs, rd and reset go, but I don't know the rest.
I haven't found a datasheet for the module, and normally i wouldn't have touched it, but it was cheap so I thought I'd give it a go.
I'm trying to build a handheld version of a PC's "Hyper Terminal" program, so I can diagnose comms without a PC.
Any help would be appreciated.
Adam
flatlander
Re: Interfacing an LCD screen (JE-AN 1286404)
PostPosted: Sat Mar 17, 2007 11:19 am     Reply with quote
Try:
* 1: VDD is connected to +5V
* 2: VSS is connected to GND
* 3: V0 - LCD operating voltage is connected from a 20k Ohm POT
*4-11: Data Bus 0 to 7 is connected to port d
*12: Chip Select 2 is connected to B1
*13: Chip Select 1 is connected to B0
*14: Reset is connected to C0
*15: R/W - Read or Write is connected to B4
*16: D/I - Data or Instruction is connected to B2
*17: Enable is connected to B5
*18: Negative voltage is also connected to the 20k Ohm POT
*19: Positive voltage for LED backlight is connected to +5V
*20: Negavtive voltage for LED backlight is connected to GND
PostPosted: Sat Mar 17, 2007 11:29 am     Reply with quote
This post in another forum, says it has an additional part number:
HQM1286404
http://www.picbasic.org/forum/showthread.php?t=5859
This thread in the CCS forum tells how to use it with CCS:
http://www.ccsinfo.com/forum/viewtopic.php?p=55734
ME109e
LCD interface
PostPosted: Sun Mar 18, 2007 10:32 am     Reply with quote
Hi guys,
Thanks for the info, much appreciated.
I'll give things a go and see where I get. If I run into any issues I call back.
Cheers
