Using getc() and putc() with Hexa data for RS232 ?
jpvr
PostPosted: Sun Mar 18, 2007 7:38 am     Reply with quote
Dear All,
Please, can you tell me if this is possible to send and receive data in hexa decimal format with getc() and putc() over the RS232 UART of a pic ???
I post this message because it seems that this two function deals only
with character format and I am not able to find a rapid method for
converting Hexa to ( and from ) Ascii with this two command ...
Thank you for your help,
Jean - Pierre Wink
PostPosted: Sun Mar 18, 2007 8:06 am     Reply with quote
That is what printf is for..
printf("%2x",val);
You can of course print the values with putc, but then you will have to call a binary to hex conversion routine first,and send the two values. The printf code, does exactly that.
jpvr
PostPosted: Sun Mar 18, 2007 8:19 am     Reply with quote
thank you for the answer.
So, then I can use printf() for sending the value but for receiving the
hexa data, what is the function ???
Must I use getc() with an aditionnal conversion routine ???
PostPosted: Sun Mar 18, 2007 9:26 am     Reply with quote
Yes. There have been efficient hextobin routines published here (there is a set in the code forum). There is a simple 'gethex' routine to get (and echo back) two hex digits from getc, and convert the result to a byte, in input.c
jpvr
PostPosted: Sun Mar 18, 2007 10:14 am     Reply with quote
Hi Ttelmah,
Thank you very much for all this precisions.
Have a nice week end,
Jean - Pierre
