ivanperino
losing pics. ICD-U40 problem. |
Posted: Fri Mar 16, 2007 4:40 pm |
PIC16F88 - ICD v2.73 - ICD-U40 firmware v2.14 rev#100 - PCHW v4.017
Hi. We think we have serious problems with an ICD-U Programmer. We have used it for a long time until a stack happened. The NOMCLR fuse and a piece of code make the PIC useless, since it becomes undetectable from the ICD! the message "Couldn't detect target chip" appears after programming. We have tested with 2 PIC 16F88 and 2 PIC16F819 and both seem damaged.
I can show you the code if it is necessary. It is a very large one
Please, any orientation or help will be crucial at this stage. Thanks for your support.
Ivan Perino, Sergio Calderon
San Luis University - Argentina
Code: | #include <16F88.h>
#device ADC=10
#fuses WDT,INTRC_IO, PUT, NOBROWNOUT, NOLVP, NOWRT, NOPROTECT, NOMCLR
#use delay(clock=8000000)
#use rs232(baud=38400,xmit=PIN_A2,rcv=PIN_B0)
#define salida_pos pin_a7 //positivo para medir
#define salida_R1 pin_a0 //activa la resistencia R1.
#define salida_R2 pin_a1 //activo la resistencia R2.
#ifndef EEPROM_SDA
#define EEPROM_SDA PIN_A3
#define EEPROM_SCL PIN_A6
#use i2c(master, sda=EEPROM_SDA, scl=EEPROM_SCL, FAST=400000)
#define PIN_COM_PC PIN_A5
