How do I printf an int32
MarcosAmbrose
PostPosted: Fri Mar 16, 2007 5:34 pm     Reply with quote
I want to printf a 32 bit variable in hex (but decimal will do) but I can't figure out the printf formatting string. Is an unsigned long int the same as an int32?
   int8 My8bitVar;
   int32 My32bitVar;
   My8bitVar=0x5A;
   My8bitVar=0xAABBA52B
   printf("Int8 Var = %X",My8bitVar)
   printf("Int32 Var = %what goes here?",My32bitVar)
....Thanks,
PostPosted: Fri Mar 16, 2007 5:47 pm     Reply with quote
See my post in this thread. It has sample code to display values
larger than a byte.
http://www.ccsinfo.com/forum/viewtopic.php?t=27832&highlight=int16+int32+printf
MarcosAmbrose
PostPosted: Fri Mar 16, 2007 5:58 pm     Reply with quote
Thanks for that...
So the "%lu" string works for both 16 and 32 bit variable. Is that correct?
Regarding the other question, Is an "unsigned long int" the same as an int32?
larger than a byte.
PostPosted: Fri Mar 16, 2007 6:00 pm     Reply with quote
No, unsigned long is the same as unsigned int16.
PostPosted: Fri Mar 16, 2007 6:03 pm     Reply with quote
%LU works for int16 and int32.
In CCS, a 'long' is a 16-bit variable. You have to use 'int32' to declare
a 32-bit variable.
See page 23 in the CCS manual. (page 33 in the Acrobat reader)
See the section on "Basic and Special types":
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
