Help on I/O port C and F
mkr
PostPosted: Fri Mar 16, 2007 11:42 am     Reply with quote
Hello Everybody,
I am facing a issue to turn ON and OFF two I/O pin.
Here is a code snippet when the outputs are turn ON
output_high(PIN_F0);
output_high(PIN_C1);
Only F0 is on and C1 is off. After this both the outputs are turned off as below
output_low(PIN_F0);
output_low(PIN_C1);
In the next condition again F0 and C1 is turned on as
In this case only C1 is on and F0 is off. After this both the outputs are turned off as below
output_low(PIN_F0);
output_low(PIN_C1);
Any one know the reason. I know it is basic, but I am stuck here.
mkr
mkr
PostPosted: Fri Mar 16, 2007 11:52 am     Reply with quote
Give a detailed description of the external circuits connected to those pins.
Also post the PIC, the oscillator frequency, etc.
kevcon
PostPosted: Fri Mar 16, 2007 12:13 pm     Reply with quote
Are they part of an IF statement?
You might be missing the braces around them.
mkr
PostPosted: Mon Mar 19, 2007 5:58 am     Reply with quote
Silly of me. I got it solved. I had few directive switches around the code. Analyised them and corected.
Sorry for the trouble.
mkr
