Unique HEX file naming?
dpaul
PostPosted: Thu Mar 15, 2007 7:09 am     Reply with quote
Greetings:
I wonder if there is any way to have the CCS compiler output a HEX file named differently from the file which includes main()?
I have core code that, depending on what is pound defined, will compile into distinct products. For all these cases, the resulting HEX file output is named the same as the file which contains main(). Obviously, this can lead to a confusing array of identically named HEX files.
I have applied #HEXCOMMENT to embed some function particulars in the HEX output, so I can always open the HEX file if I question what product it is intended for, or rename them manually.
It would be snifty if there were a compiler directive that automatically renamed the HEX file output. Are there any facilities to get the compiler to help out?
Thanks,
Doug
PostPosted: Thu Mar 15, 2007 12:40 pm     Reply with quote
A work-around is presented in the last post from Ttelmah:
http://www.ccsinfo.com/forum/viewtopic.php?t=29983
