Pointer problem
VanHauser
Pointer problem
PostPosted: Sun Mar 11, 2007 5:08 am     Reply with quote
I have wasted hours trying to solve an annoying problem with pointers that previously did not appear in my program. I noticed it when my program got bigger (85% of an 18F452). Compiler is 3.249.
I have this piece of code:
struct str_input_s {
  char *ptr;                // Pointer to the source/destionation variable
  char s[UNIT_CHARS+1];     // String for char entering, UNIT_CHARS max!!
  int8 len;      // String length
  int8 i;        // Current char being modified
  int8 menu_id;  // Menu in which the variable is in
  int8 menu_s;   // The variable's position in the menu
} strinput;
void init_input_string(char *ptr, int8 len, int8 menu_id, int8 menu_s) {
  strinput.ptr = ptr;
  strncpy(strinput.s, ptr, UNIT_CHARS+1);
  printf("ptr=%ld\r\n", ptr);
Here is the call to this function:
printf("param_ptr=%ld\r\n", menu.param_ptr[menu.s]);
init_input_string(menu.param_ptr[menu.s], UNIT_CHARS,   // Pointer, len
                  menu.id, menu.s);                     // menu_id, menu_s
menu.param_ptr is an array of void pointers and that location correctly prints out to be 148, but when I print ptr inside the init function, this one is 0. What am I doing wrong? This code worked ok before.
PostPosted: Sun Mar 11, 2007 12:40 pm     Reply with quote
Can you post a test program ? Then I can work on it.
It doesn't have to be long. Just the code that you posted,
plus all missing declarations. Just so it will compile.
VanHauser
PostPosted: Sun Mar 11, 2007 1:32 pm     Reply with quote
I hate when it happens like this, the test program below works as expected.
#define CLKSPEED 40000000
#include <18F452.h>
#fuses H4,NOPROTECT,WDT,NODEBUG,NOLVP
#use delay(clock=CLKSPEED)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7, enable=PIN_C5, parity=N, bits=8, restart_wdt, errors)
#include <string.h>
#zero_ram
#define  UNIT_CHARS  5
#define  OPT_MAX     13
// Data for a menu
struct menu_s {
  int8 id;                           // Current menu id
  signed int8 s;                     // Current selected option
  int8 length;                       // Number of options
  void* param_ptr[OPT_MAX];     // Pointers to the source data
} menu;
// Data for the string input task
} strinput;
  strinput.ptr = ptr;
/**/printf("ptr=%ld\r\n", ptr);
/**/puts(strinput.s);
/**/puts(ptr);
  strinput.i = 0;
  strinput.len = len;
  strinput.menu_id = menu_id;
  strinput.menu_s = menu_s;
struct {
  char str[3][6];
} test;
   // Disable everything by default
   setup_low_volt_detect(FALSE);
   setup_oscillator(OSC_NORMAL);
   setup_adc(ADC_OFF);
   setup_adc_ports(NO_ANALOGS);
   setup_timer_0(RTCC_OFF);
   setup_timer_1(T1_DISABLED | T1_DIV_BY_1);
   setup_timer_2(T2_DISABLED, 255, 1);
   setup_timer_3(T3_DISABLED | T3_DIV_BY_1);
   setup_ccp1(CCP_OFF);
   setup_ccp2(CCP_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
                            // 7       6       5       4       3      2       1       0
   set_tris_a(0b11010000);  // x       x       LED1    DOUT    DIN    CLK     CS_DAC  CS_ADC
   set_tris_b(0b11110000);  // PGD     PGC     PGM     x       REL4   REL3    REL2    REL1
   set_tris_c(0b10011111);  // RX      TX      RE_DE   x       KEY4   KEY3    KEY2    KEY1
   set_tris_d(0b11111111);  // LCD_D7  LCD_D6  LCD_D5  LCD_D4  LCD_L  LCD_EN  LCD_RW  LCD_RS
   set_tris_e(0b11111000);  // x       x       x       x       x      LED4    LED3    LED2
   strcpy(test.str[0], "aaaaa");
   strcpy(test.str[1], "bbbbb");
   strcpy(test.str[2], "ccccc");
   menu.id = 0;
   menu.s = 0;
   menu.length = 3;
   menu.param_ptr[0] = test.str[0];
   menu.param_ptr[1] = test.str[1];
   menu.param_ptr[2] = test.str[2];
/**/printf("param_ptr=%ld\r\n", menu.param_ptr[menu.s]);
   init_input_string(menu.param_ptr[menu.s], UNIT_CHARS, menu.id, menu.s);
   while(1) restart_wdt();
This prints:
param_ptr=49
ptr=49
aaaaa
aaaaa
which is ok. In the main program ptr would have been 0.
I also noticed similar problems with float parameters passed by refference to a function. That float was zero in the function. I removed the & and the problem was solved. Of course, this appeared after my program grew in size Sad
Can't this compiler be safely used with programs bigger than average? It is getting very annoying trying to find workarounds for the bugs in the compiler.
VanHauser
PostPosted: Sun Mar 11, 2007 5:08 pm     Reply with quote
It seems to me that when dealing with large programs, the compiler fails to evaluate some function parameters. I fixed my problem replacing this:
with this:
void *ptr;
ptr = menu.param_ptr[menu.s];
init_input_string(ptr, UNIT_CHARS, menu.id, menu.s);
