digital clock count
wakaka
digital clock count
PostPosted: Sun Mar 11, 2007 7:40 am     Reply with quote
Hi all, i would like to use PIC16F876a to build a simple digital clock.
Below is partial of the code :
for(i=0; i <= X; i++) {
         delay_ms(1000)
         clock = clock +1;
The problem is what is the maximum value for X that CCS are supported. If according to calculation, 1 day consist of 86400 seconds. If i divide the Should i put X = 86400? or should i break in to for loops?
Plz guide, thanks.
jecottrell
PostPosted: Sun Mar 11, 2007 8:56 am     Reply with quote
Look at the following link:
http://www.ccsinfo.com/forum/viewtopic.php?t=26177
I use this code whenever I need an RTC and I haven't included an RTC IC.
Look at the compiler manual and read about the data types. You will see what the largest is.
Good luck,
John
