Lorenzo1588 Guest
Brace insert |
Posted: Sat Mar 10, 2007 9:47 am |
What should I press to insert brace ( '{' and '}' )?
With PCWH 4.020 alt123 doesn't work! |
Humberto
Posted: Sat Mar 10, 2007 10:26 am |
To insert brace ´{´and ´}´you shoul press ´{´and ´}´, the point is how to reach
such symbols in your keyboard. Normally they are accessed using the AltGr
modifier key. If you already can see those symbols marked in your keyboard,
AltGr is often used to type that symbol, press "AltGr"+"{" simultaneously.
If the symbols are not marked in any key, you should try to find them "hidden"
in some keys in the righ hand side of your keyboard.
Humberto |
lorenzo1588 Guest
Posted: Sat Mar 10, 2007 10:50 am |
the symbols are not marked in my keyboard |
Posted: Sat Mar 10, 2007 11:00 am |
One alternative, if you cannot find the combination, is to use ALT 123 typed on the keypad (and 125 for the closing brace). If you push the 'alt' key, and then holding it down, type a digit numeric sequnce on the keypad, then release the 'alt', the number sequence is treated as an octal value, to give any character at all (including ones not normally available on the keyboard).
lorenzo1588 Guest
Posted: Sun Mar 11, 2007 11:25 am |
I know but this (only for pcwh 4) doesn't work too, |
