Software Uart Problem
soulweed
PostPosted: Wed Mar 07, 2007 2:33 pm     Reply with quote
I am using PIC18F452
Now I try 1 HW UART and 1 SW UART but SW UART doesn't work,I need to use INT signal on it.
Do you think about this solution?
#include<18f452.h>
#use rs232(stream=CH1,baud=9600,xmit=PIN_C6,rcv=PIN_C7)  //HW UART
#use rs232(stream=CH2,baud=9600,xmit=PIN_B1,rcv=PIN_B0,FORCE_SW)//SW UART
short int hook_rx=0;
short int hook_rx2=0;
#INT_RDA //Interupt Rx routine
void RxD_ISR(void){
      char ch;
      ch = getc();
                     hook_rx=0;
#INT_EXT//Rx2 INT routine
void RxD2_ISR(void){
      char ch;
      ch = getc();
                     hook_rx2=0;
Are this solution must be set tris_b for B1=output and B0=Input ,Are not?
PostPosted: Wed Mar 07, 2007 2:39 pm     Reply with quote
When you streams, you need to use the CCS functions that allow you
to specify the stream. Instead of getc(), you should use fgetc(stream),
and enter the stream as the parameter. Do this for all rs232 functions
when you use streams.
Also, just use standard i/o (the default mode) and let the compiler
handle setting the TRIS.
Humberto
PostPosted: Wed Mar 07, 2007 2:47 pm     Reply with quote
Also -assuming that your hardware is ok- you will need to include this statements
in the init:
ext_int_edge(H_TO_L);
enable_interrupts(INT_EXT);
enable_interrupts(INT_RDA);
Humberto
