		| View previous topic :: View next topic   |
			soulweed
				| What PART Number for PDIP 40 PIN |
				 Posted: Mon Mar 05, 2007 6:45 pm     |
				| PIC18*  40 PIN PDIP two UART  ,please me |
				 Posted: Mon Mar 05, 2007 7:33 pm     |
				1. Go to the parametric search page on the Microchip site for the PIC18:
http://www.microchip.com/ParamChartSearch/params.aspx?branchID=1004&mid=10&lang=en&pageId=74
2. Go about halfway down the page.   Select these boxes:
 	  | Quote: | 	 		  | x 2 AUSART    x  2 EUSART |
3. Then go the bottom of the page and click the "Search" button.
4. When it finishes searching, click the "Detail" button.
5.  Now you have a list of PICs.   Scroll over to the right side
    of the page.   You can see the column for "Pin Count".
That will give you the answer. |
			future
				 Posted: Tue Mar 06, 2007 7:10 pm     |
				I remember these...
18F452
18F458
18F4520
18F4525
18F4620
The flash size increases downwards. |
				 Posted: Tue Mar 06, 2007 7:56 pm     |
				He wants two UARTs:
 	  | Quote: | 	 		  | PIC18* 40 PIN PDIP two UART ,please me |
			soulweed
				 Posted: Wed Mar 07, 2007 5:23 am     |
				I saw in microchip website ,any part Number is PDIP has two UART .I am so sorry.
however I fighting for my senior project
so i need to know about I get INT of my software UART because
I'm try to  use  MAX3100 ,it doesn't  work.i don't know WHY ?
I think problem may be occurs  HARDWARE  more than Sofware because
when I coding I try to SIMMULATE in software and see Timing Diagram,
it correct.Then I think it ERROR By hardware.
#include <18f452.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use rs232(baud=19200,xmit=PIN_C6,rcv=PIN_C7)
#define MAX3100_CS     PIN_C0
#define MAX3100_IRQ    PIN_B0
#define MAX3100_CLK    PIN_C3
#define MAX3100_SDI    PIN_C2
#define MAX3100_SDO    PIN_C4
static unsigned char recv1;
static unsigned char recv2;
static unsigned char recv3;
static unsigned char recv4;
static unsigned char recv5;
static unsigned char recv6;
static unsigned char flagSPI;
/*   ##############   Main   ##################   */
unsigned char read_spi(unsigned char data);
void readMAX3100(unsigned char command,unsigned char data);
void spiputc(unsigned char data);
#INT_EXT
void interrupt_spi(void)
        output_low(MAX3100_CS);
        recv3 = read_spi(0x00);
        recv4 = read_spi(0x00);
       delay_us(1);
        output_high(MAX3100_CS);
      output_low(MAX3100_CLK);
      output_low(MAX3100_SDI);
    //    output_low(MAX3100_IRQ);
      printf(spiputc,"%2X",recv4);
   //   printf("%2X\n\r",recv4);
      flagSPI = 0;
unsigned char read_spi(unsigned char data){
   unsigned char x;
   unsigned char temp;
   temp = 0;
   for(x=0;x<8;++x)
      if(data & 0x80){
        output_high(MAX3100_SDI);
      else{
        delay_us(1);
        temp = ((temp <<1) | input(MAX3100_SDO));
        output_high(MAX3100_CLK);
        delay_us(1);
        data = data << 1;
   return(temp);
   unsigned int temp;
   readMAX3100(0x00,0x00);
    while((recv1!=0x40) & (recv1!=0xC0))
   readMAX3100(0x80,data);
   while((recv1==0x00))
       delay_us(1);
        recv1 = read_spi(command);
        recv2 = read_spi(data);
       delay_us(1);
 unsigned  char  command,SPIcommand,temp1,temp2;
 unsigned int max3100Read;
    ext_int_edge( 0, H_TO_L);
     enable_interrupts(INT_EXT);
      readMAX3100(0xC4,0x0A); //Write Config Command and set baud to 9600
for(;;){
    flagSPI = 0;
   printf(spiputc," TEST USART-SPI Max3100   \n\r");
      if(flagSPI==1)
         flagSPI = 0;
/*   ##############   END   ##################   */
