problems with int16 or methods
sonicfire
PostPosted: Tue Mar 06, 2007 12:24 pm     Reply with quote
Right now, I'm drawing up an outline for my dc motor control. I was trying to compile this preliminary program, but I get error messages that say "A numeric expression must appear here" for all the lines that say int16. Does this have something to do with the way I wrote the methods (my programming skills are rusty). Thanks for your help. Here's the code:
#include <16F877.h>
#device adc=10
#use delay(clock=10000000)
void check_reset()  {
   int reset_value = 0;
   while (reset_value==0)  {
      reset_value = input(PIN_B1);  //delays circuit until user resets circuit (emits high signal to pin B1
int check_current()  {
   set_adc_channel( 0 );
   int16 current_value;
   current_value = (read_adc()*512)/1024;
   int overload;
   if (current_value > 5)   //NOT SURE WHAT THIS VALUE WILL BE YET, BUT 5 is probably a good guess
      overload = 1;
      overload = 0;
   return overload;
int check_speed()  {
   return 0;      //not sure how to handle this just yet...
void compare_with_user()  {
   int16 value1;
   int16 value2;
   value1=(read_adc()*512)/1024;     //note, adc_channel should already be set to 0 from check_current method!
   delay_us( 10 );               //10uS delay is necessary for proper ADC reading.
   value2=(read_adc()*512)/1024;
   //COMPARISON GOES HERE...
   set_pwm1_duty(value1);
   /*   This sets the time the pulse is high each cycle.
      The high time will be:
      if value is LONG INT: value*(1/clock)*t2div
      if value is INT: value*4*(1/clock)*t2div
      for example a value of 30 and t2div of 1 the high time 12uS
      A value too high or too low will prevent the output from changing.
   setup_ccp1(CCP_PWM);   // Configure CCP1 as a PWM
   setup_timer_2(T2_DIV_BY_1, 24, 1);  //output at 50KHz
                              //Period = (1/clock)*4*t2div*(period+1)
   setup_port_a(ALL_ANALOG);
    setup_adc(adc_clock_internal);
   int shutdown1;
   int shutdown2;
   while( TRUE ) {
   shutdown1 = check_current();     //returns 0 if okay and 1 if overloaded
   shutdown2 = check_speed();      //returns 0 if okay and 1 if it's too fast
   if ( (shutdown1==0)&&(shutdown2==0) )
      compare_with_user();
   else {
      set_pwm1_duty(0);
      check_reset();
PostPosted: Tue Mar 06, 2007 12:33 pm     Reply with quote
All local variables must be declared at the start of the function,
before any code.
sonicfire
PostPosted: Tue Mar 06, 2007 12:44 pm     Reply with quote
That did the trick! Many thanks...
rwyoung
PostPosted: Tue Mar 06, 2007 1:55 pm     Reply with quote
before any code.
sonicfire - get a copy of Kernighan and Richie's "C Lanugage" 2nd edition. In ANSI C (and in CCS's decidedly non-ANSI C) you MUST complete all declarations prior to starting code in the body of a function.
C++ however relaxed that requirement.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
