HELP ME
moon
HELP ME
PostPosted: Sun Mar 04, 2007 3:50 am     Reply with quote
ITHANK YOU FOR YOUR ANSWER ,BUT I AM A BIGGENER IN BROGRAMMING SO PLEASE GIVE ME THE CODE FOR THE INTERRUPT KNOWING THAT I AM USING THE FULL WAVE AC SIGNAL Embarassed
dyeatman
PostPosted: Sun Mar 04, 2007 8:41 am     Reply with quote
OK so you are a beginner. Lots of those here.
Some things to start:
1. PLEASE DONT USE ALL CAPS. It looks like you are shouting. If you continue, it is unlikely you will get any help.
2. We understand you are a beginner but it will take more than code to make your project happen. Be aware folks here will be glad to help you but are not going to do your project for you, so you will have to put some effort in.
3. Later, when you post code, use the code button at the top of the screen to keep the formatting.
4. We will need to know what kind of hardware you are using and how it is connected.
5. We know you have the 16F877, what version CCS compiler are you using?
6. To get this to work you will need an interface circuit to condition the signal going to the PIC. What do you have so far, anything?
7. Search this board on the words "zero + crossing" and you will find a fair amount of code and other information to help you get there like:
http://www.ccsinfo.com/forum/viewtopic.php?t=26861
and
http://www.ccsinfo.com/forum/viewtopic.php?t=21869
and
http://www.ccsinfo.com/forum/viewtopic.php?t=20664
and
http://www.ccsinfo.com/forum/viewtopic.php?t=29995
and
http://www.ccsinfo.com/forum/viewtopic.php?t=28124
Finally, DO NOT start multiple threads and keep begging for someone to help. If someone is going to help, one thread is enough.
Good Luck!
