compiling error |
Posted: Wed Feb 28, 2007 1:13 am |
I'm using PCWH 4.023 to compile my c program through MPLAB IDE v7.50 enviroment
After compiling my program about 4-5 times, a dialogue box with the below text will appear and the IDE closes.
the application at "0x74725b41" referenced memory at "0x00000002". The memory could not be "read".
What's wrong? |
KaraMuraT
Joined: 16 May 2006 Posts: 65 Location: Ankara/Turkey
Posted: Wed Feb 28, 2007 3:55 am |
Did you try to use MPLab 7.51? If you installed while the 7.50 is installed and then removed, 7.50 can cause such troubles.
Just remove everthing about MPLab and then reinstall 7.50. And never install 7.51 It's the most buggy MPLab version I've ever seen.
And another idea.. Sometimes CCSC.exe can stop responding but sits in the memory. This can cause such memory exceptions for MPLab. Just open the Task Manager and find CCSC.exe in the processes list and remove from the memory. _________________ /// KMT
/// www.muratursavas.com |
Posted: Sat Mar 03, 2007 4:07 pm |
I beleive that there are quite a few bugs left to fix in MLPLAB v7.5x. I have the same problems as you do (and many more) but it appears to have nothing to do with the CCS Compiler. Sometimes MPLAB crashes if I try to open a file directly after startup. It appears to crash randomly, but at least five times a day, messing up the project so I need to make a new one and set all the config bits (guess how glad i am when I've made a new project for the fifth time).
I've contacted Microchip support, they claim that they never heard the problem before... They guess it may have something to do with my computer configuration or windows environment. I have MPLAB with CCS Compiler (PCWH 3.245) both at work and at home. At work it crashes at least five times a day but never at home (I wish it was the other way around). I've tried to remove all of v7.50 components and installed v7.52. It actually works a little bit better, but it still crashes a few times a day. |
kevcon
Joined: 21 Feb 2007 Posts: 142 Location: Michigan, USA
Posted: Thu Mar 08, 2007 8:45 am |
I'm using MPLAB 7.52 and CCS 4.027 and MPLAB crashes every time after about 20 compiles.
I just did a test using with an assembly file just using MPASM and had no crashes after 50+ compiles, I'm wondering if the CCS pulgin has a stack overflow problem. |
