gdl_pro1 Guest
12f629 RS232 |
Posted: Thu Mar 01, 2007 11:53 am |
Hi Guys. I have 2 days stuck trying to get RS232 comunication with the 12f629.
My compiler version is 5.00.2195.6601 and I'm using a MAX232.
I'm sure that the hardware is working because I'm also making a code for the 16f877 and It works fine with it. Both the terminal and the code are set to baud=2400, parity=N,bits=8,hardware. By the way, before using the 12f629 for the first time, I saved the OSCAL, I have compared it and has not changed.
I get the correct number of bytes but they are corrupted. exaple, the pic should send 0x42 but gets 0xE2
By the way, I downloaded a demo version of a competitors compiler and the RS232 worked, so that means it is not hardare. So it reduces the posibility to a code error or a compiler error. I cannot use the competitors compiler since I have all code of all the projects in the CCS compiler.
I will apreciate if anybody can take a look at the code. Maybe you will have an opportunity to tell me how stupid I'm
Thanks in advance
Code: | #if defined(__PCM__)
#include <12f629.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,PUT,NOMCLR
#use rs232(baud=9600, parity=N, xmit=PIN_A2, RCV=PIN_A3, bits=8,RESTART_WDT)
int16 i;
int8 D;
//Blink a LED to be sure that the pic start
output_high(PIN_A4);
delay_ms(400);
output_low(PIN_A4);
delay_ms(400);
delay_ms(400);
output_low(PIN_A4);
delay_ms(400);
delay_ms(400);
output_low(PIN_A4);
delay_ms(400);
printf("HELLO");
putchar(0X42);
if (kbhit() )
putchar(0X42);
D = getchar(); // wait for command char
putchar(D);
if ( D == 'b' )
putchar(0X55); // return test values
delay_ms(16);
putchar(0XAA);
D=0;
Posted: Thu Mar 01, 2007 12:10 pm |
Quote: | Both the terminal and the code are set to baud=2400 Code: | #use rs232(baud=9600, parity=N, xmit=PIN_A2, RCV=PIN_A3, bits=8,RESTART_WDT) |
gdl_pro1 Guest
Posted: Thu Mar 01, 2007 12:22 pm |
Ooops. Yes you are right. I have been working with seral options of bauds, parity, reverse, ect. to try to make it work. without any luck
Actual code (same as terminal).
Code: | #use rs232(baud=2400, parity=N, xmit=PIN_A2, RCV=PIN_A3, bits=8) |
Posted: Thu Mar 01, 2007 12:27 pm |
You have the RESTART_WDT option enabled in the #use rs232 statement, but have the watchdog timer disabled with the NOWDT fuse. Try remvoing the RESTART_WDT option. |
gdl_pro1 Guest
Posted: Thu Mar 01, 2007 12:32 pm |
By the way, the correct version of the compiler is "Version 3.107, 15848" The version that I posted before was from the help file. |
gdl_pro1 Guest
Posted: Thu Mar 01, 2007 12:38 pm |
Thanks I removed it, same issue only trash in Terminal |
Posted: Thu Mar 01, 2007 2:11 pm |
Your version doesn't support the 12F629 very well. The CCS start-up
code is incorrect, and the code for the setup_comparator() function is
incorrect. Change the first part of your program so it looks like this,
and it may start working.
#include <12F629.h>
#use rs232(baud=9600, xmit=PIN_A2, RCV=PIN_A3)
#byte OSCCAL = 0x90
#byte CMCON = 0x19
// If you erased the OSCCAL value, then un-comment this line.
// #rom 0x3FF = {0x3480}
int8 D;
#asm
call 0x3FF // Read the OSCCAL value
movwf OSCCAL // Load it
#endasm
CMCON = 7; // Comparator off
gdl_pro1 Guest
Posted: Thu Mar 01, 2007 3:02 pm |
It woooooorks!!!!
Thank you. I would had never figured it out myself.
Now I can stay with CCS. |
