LCD troubles Help please
Wojtek
PostPosted: Tue Feb 27, 2007 8:54 am     Reply with quote
Hello I have quite problem with LCD display. I am using standard 16x2 Lcd that was added to software prototyping board. In my code I add lcd.c libary and i tried to use init_lcd() function, unfortunatley the compiler seems to get stuck in that function and dose not go any further. Could you please send me a datasheet of that LCD. I the LCD.c only four wires are connected to LCD, but in the data sheet http://info.hobbyengineering.com/specs/MTC-C162DPRN-2N-V10.pdf all 8 are used. Could you expalin my how it is passible to manage LCD with only 4 wires ?
I am looking forward to hearing form you
WW
rnielsen
PostPosted: Tue Feb 27, 2007 9:04 am     Reply with quote
Looking at the spec. sheet you posted, it will take a minimum of 10 wires to control the LCD. 2 for power, 1 for contrast, 4 for data lines and 3 for control signals. You might need to connect up the remaining wires.
Ronald
rnome
PostPosted: Tue Feb 27, 2007 7:41 pm     Reply with quote
hi mate
i m workin on lcd for a week and i done it without any problem and i add my circuits schematic. ucan use it to fix yours
#include <16F877.h>
#device ADC=8
#fuses XT,NOWDT,NOPROTECT,NOLVP
#include <lcd.c>
int data_a0, data_a1;
   setup_adc_ports(ALL_ANALOG);
   setup_adc(ADC_CLOCK_DIV_8);
   for(;;)
      set_adc_channel(0);
      read_adc(ADC_START_ONLY);
      delay_us(100);
      data_a0=read_adc(ADC_READ_ONLY);
      set_adc_channel(1);
      delay_us(100);
      data_a1=read_adc(ADC_READ_ONLY);
      lcd_init();
      lcd_gotoxy(1,1);
      printf(lcd_putc, "%03u 1.axis\n",data_a0);
      printf(lcd_putc, "%03u 2.axis\n",data_a1);
      delay_ms(200);
and this codes can help u to test the circuit
live fast, never rest and do your best
rina
Re
PostPosted: Wed Feb 28, 2007 3:18 am     Reply with quote
hey dude,
the lcd blinks after a period of time.. wat to do then...
